Turbo Opinion from Yall
Old 11-02-2008, 04:39 PM
trnsfmr99's Avatar
Default Turbo Opinion from Yall
I'm about to begin the second stage of my car's project. What would you all suggest for a stock-internal LS-6, with LS-1 heads. Let me give yall the specs on the car now. It ran a 12.4 at 111mph on the motor and an 11.5 at 125 mph on nos (bottle pressure was 720psi). I'm tired of nos, so i sold the kit the next day. The car has Moser 12-bolt, w/ 3.73 gears, tranny built by T-56 rebuilds, 1 7/8 hedders, y-pipe and tuned by Thunder Racing, dynoed 390rwhp on the motor. I'm looking to have more racing from a roll than at the track. I'm also curious how much hp can be gained and ran safely with the setup I just described to yall. Also, let me know if yall know someone that's selling a turbo kit, however, i'd rather purchase from a dealer. Thanks guys!!!
Old 11-04-2008, 01:27 AM
headed-ws6's Avatar
What are your goals? How much hp are you wanting to shot for? Most people dont go over 8 psi on a stock shortblock. which is usely good for about 500rwhp.
Old 11-04-2008, 06:48 AM
geeteego's Avatar
Roll racing? STS.
Old 11-06-2008, 01:18 AM
trnsfmr99's Avatar
My goal is to suprise these upcoming "exotic" cars on the interstate and smoke em from a roll. I was hoping for around 550 to 600 rwhp with the setup i have now. I also read where there are stock blocks with all stock internals (stepped up cam, of course) laying down 600 to 650 rwhp with a turbo. That's my goals.
Old 11-06-2008, 11:29 AM
67Firebird455's Avatar
600-650rwhp and longevity I don't believe go hand in hand. Too much risk, and too hard on stock components, just a momentary lean condition, and the thing grenades. I honestly believe you can build a reliable "street car" in the 500-550rwhp range. Add a set of #317's to knock down the compression a tad, and run it. If you want to get greedy, add a little meth, that'll get you where you want to be.
Old 11-06-2008, 11:50 AM
booooost's Avatar
do an sts kit. nice on highway
Old 11-06-2008, 12:49 PM
BlownVette 2001's Avatar
A nice front mount single turbo would be nice and nobody could see it unlike the rear turbos which kind of hang low.
Old 11-06-2008, 12:53 PM
Yellowsierra's Avatar
STS turbo!
flewbyyou04r1's Avatar
X2 very well said!!
Old 11-06-2008, 08:53 PM
trnsfmr99's Avatar
Thank yall!!! I'm learning plenty. Your suggestions are greatly appreciated and i'm taking it all in. How long does the an average front mounted turbo kit last for an f-body?
Old 11-06-2008, 11:08 PM
If it's set up correctly, it'll last longer than the engine! *wink* Get a pressure regulation system setup on the feed so you don't blow oil past the seals, and make sure you keep fresh oil lubricating that bad boy. As long as you don't back spin it, or constantly overspin (surge) it, you'll be golden!
Old 11-07-2008, 12:40 PM
trnsfmr99's Avatar
Thanks 67firebird!!!
Old 11-07-2008, 12:44 PM
You're very welcome, don't mind giving out information I learned the hard way! =) Good luck with the build! PM me if you have any other questions.
Tony
Old 11-07-2008, 02:32 PM
pozesd99''s Avatar
my buddy drew ran a procharger d1 on a stock ls1 and made 640rwhp and lasted over a year without problems... nic d's tunes are right spot on
tune is everything.... his motor never blew, just he stepped up and has one of the fastest vettes in arizona...
11.7 @ i think 144mph lol hahahahaha on 315bfg drag radials full street car
Old 11-08-2008, 08:22 PM
trnsfmr99's Avatar
For what its worth, for the install, i have someone that can install with no problem. Do yall have any suggestions for tuning within about a 300 mile radius of Baton Rouge, besides Thunder Racing (not saying anything negative about them)?
Old 11-09-2008, 08:05 PM
Turbo 6.0's Avatar
Properly installed rear mount turbos do NOT hang any lowere than any other factory components...
Old 11-09-2008, 08:06 PM
Turbo 6.0's Avatar
Turbos do not have seals...
Old 11-09-2008, 08:16 PM
WS6HUMMER's Avatar
Just realized you were from La too, a friend of mine just had a cam, converter, my old hooker LT's installed, & a dynotune @ Futralls & he's pretty happy with things.
Old 11-09-2008, 11:34 PM
Really depends on the size of the turbo and the car you are hanging it on.
The STS system hangs lowere on vettes unles you cut the center trunk out.
Old 11-09-2008, 11:44 PM
Rings, do you want me to call them rings instead of seals? Oil retainers? What SHOULD I call them? I merely said too much oil pressure, and too much volume will blow oil past whatever you want to call them, I call them seals, although they're not rubber, etc.
Quick Reply: Turbo Opinion from Yall
