Some HDR's (My Camaro & Fall Foliage)
Old 11-03-2008, 01:26 PM
HibachiZ28's Avatar
Arrow Some HDR's (My Camaro & Fall Foliage)
From Sunday. D70s, 18-70, Photomatix, no Photoshop, though it could use some sharpening and levels adjustments:
From Sunday as well.. nothing special.
Non HDR's:
Not a good shot, but I like Bokeh lol:
Old 11-03-2008, 01:31 PM
whatsgrip?'s Avatar
Thats it! Im driving to wherever West Chester, PA | Brick, NJ is and you're taking pictures of my car...lol... nice shots
Old 11-03-2008, 01:41 PM
Detoxx03's Avatar
Out of curiosity is hdr a option on the camera or computer software? Nice pics btw.
HibachiZ28's Avatar
I spend my weekdays living here in West Chester, PA. It's a 45 minute drive from the Philly Airport depending on traffic/time of day. Ever seen "Viva la Bam", "Bam's Unholy Union" or "Jackass"? 90% of Viva la Bam & Bam's Unholy Union and prob 50% of Jackass are/were filmed here. Aside from that, it's a great little town.
But seriously, if you're out here sometime, let me know and I'll give you some discounted rates to shoot your ride.
Old 11-03-2008, 01:43 PM
HibachiZ28's Avatar
Since I am asked this quite a bit, I found a previous reply I wrote on another forum lol:
HDR refers to High Dynamic Range. It basically allows you to photograph a subject as it truly appears, or BETTER in many cases.
The basic principal behind it... I use a Nikon D70s. It allows me to use "Bracket" shooting. I set my bracketed shots for 3 shots, each 2 stops different from the other. This basically creates three photos: -2, 0, and +2. You then use a program, Photomatix in my case, to merge them together. Once merged, it's still nothing special. You then need to use that program to "Tone Map" the new single image. This is what brings out the final product.
You can also use just one imagine, ONLY if it's a RAW image. This helps for you to take photos in diverse conditions (moving vehicle traffic, pedestrians, trees, whatever). You then use a RAW editing program to change the stops manually as with the 3 photo routine. You then save 3 versions of that original RAW. -2, 0, and 2 EV as before. Make sure the RAW editing program does NOT save file info, and if it does delete it. If this is not done, it will not work properly and will look like poop. At this point, you then go ahead and Tone Map as before, and you get a similarly good final product.
Old 11-03-2008, 03:17 PM
H21surfer's Avatar
Nice pictures!
Does that tree have a face?, or have I just lost my mind.
Old 11-03-2008, 03:21 PM
whatsgrip?'s Avatar
Originally Posted by H21surfer
Nice pictures!
wtf.... i just noticed that....
Old 11-03-2008, 03:22 PM
Mr. Luos's Avatar
Only great camera's can pull this off.
My 300D won't do it. The sensor doesn't pick up enough of the detail unless I get all three exposures.
Well...let me rephrase that. It will do it, just doesn't come out all that well. Basicly either looks overprocessed or like the source file.
Old 11-03-2008, 03:25 PM
HibachiZ28's Avatar
Yes, the tree has a face LOL.
Mr. Luos: Are you sure you are deleting ALL the EXIF data that's attached to the copies of the RAW file you make? You need to delete the original, and if it allows you, edit it to be -2 and +2. That's the only way it'll actually work as Photomatix uses EXIF data to do it's thing.
Old 11-03-2008, 03:32 PM
Mr. Luos's Avatar
Not sure on the EXIF data.
I'll have to check.
I know PhotoMatix asks me what steps the exposure is....and I have to pick it. The 3 exposure route it doesn't ask. Meaning I assume the EXIF data isn't deleted.
Although, I normally throw them in PhotoMatix as TIFF's.
Old 11-03-2008, 03:46 PM
HibachiZ28's Avatar
Yah you definitely have to edit the EXIF data or it'll look like excrement.
Old 11-03-2008, 04:16 PM
speedy_2's Avatar
Too many black spots in these. nice car though. The fall colors are nice as well.
Detoxx03's Avatar
Thanks man great info
Old 11-03-2008, 04:35 PM
HibachiZ28's Avatar
The "black spots" as you refer to them are called "noise." It's part of photography. It's always there, just in varying amounts with some being incredibly easy to see and others being nearly impossible. If you want further info, read here:
http://www.imatest.com/docs/noise.html
And you're welcome for the info.
Old 11-03-2008, 04:44 PM
speedy_2's Avatar
I know what noise is. I mean black areas I guess. Not specks or spots.
Or you can look at it as a "halo" around the trees. Which is a better description of what I was talking about..
It's in pics #1, 4, 5, and 6.
Old 11-03-2008, 05:28 PM
HibachiZ28's Avatar
Oooh, the shadowing/ghosting effect or w/e you want to call it. Yah I get carried away looking at the main image and often times forget about that happy medium where the trees and sky collide.
Old 11-05-2008, 04:59 PM
hitmansws6's Avatar
Some of those shots would look much better NOT processed as HDR. Just my opinion.
Old 11-05-2008, 07:06 PM
HibachiZ28's Avatar
I can show you the photos next to the non-HDR versions. The HDR's are so much better. Hands down. My album is here if you want confirmation of that:
http://pafirefighter11.smugmug.com/g.../6447228_t4nC6
Old 11-05-2008, 09:49 PM
speedy_2's Avatar
Over Saturation, contrast, and poor HDR edits will never look better than proper post processing.
I PP these from the link you gave, using only one single JPEG.
Old 11-06-2008, 12:50 PM
jhelms's Avatar
Smugmug rocks doesn't it?
I am using a D200 and just downloaded photomatix and tried a few HDR's, not sure if I'm doing the 'details enhancer' stuff right... how do these look?
My first little try with HDR... how does this look?
