No way! More bad luck for ninetres???
Yep. Big surprise.....I know. My trans or awesome fuddle converter has an issue. Its a Rossler TH400 stg2 that was re-freshed by Mikes Transmission, 14 passes and 1k miles ago. Started whining real loud right now with RPM. Also slow shifting gears once I pull the lever. Gonna try a new filter TM....but I'm sure its a pump or something
Bad thing is that I am pre-registered (and pre paid) for an LSx only private track day on Nov 22nd......and I'm pretty much broke. Poop.
One of me techy friends "thinks" it might be the converter since it makes the noise in neutral as well and corresponds with rpm. Thoughts? If its the converter the whole engine needs to be re-built with a different crank.......LONG sad story that you can read about in my previous threads.
