Y block or T'd hoses to supply rails?
I was planning a fuel line from fuel cell, into a Y block. Then two hoses out of Y block going to each rail.
It was suggested to me to use a T fitting closer to the rails to clean up some of the routing (2 hoses going to the rails) from the side of engine compartment.
If I do so is there a significant pressure difference? What's the norm for a boosted application?
Jeff
Jeff
Thanks.
Yeah, I think I'll be pushing 900bhp so I am a little worried what using a T vs. a Y might do. I'd rather use the T because it's less hose to run and less fittings.
J
J
