tv 2 cam..what do shift at?
Old 11-04-2008, 06:04 PM
silverLSWON's Avatar
Default tv 2 cam..what do shift at?
just wondering what people with the TSP torquer 2 cam are shifting at going down the track. my mph seems kinda low to me and i am wondering if i am shifting to high or if my gear is to steep. i shift right when my factory tach reads 7 so i am guessing i am right around 67-6800 rpm. i also have 4.56 gears and run on 10.5 x 27 qtps. going through the traps my tach reads about 72-7300 in 4th gear. i'm thinking i have a little to much gear. i don't really want to do a 28" tall tire either. my mph is only 114 115 when i should be around 118. i am not to worried about mph but let me know what you think
Old 11-04-2008, 07:21 PM
itsjustaSB's Avatar
when i had mine i was shiffting it at 6500 cause thats wear it peaked at coulda got a couple more hundred but i didnt think it was safe on the stock block with older rod bolts and my trap on motor was the same as yours i was runing stock 243 cast heads with 40 mill gaskets hope it helps
Old 11-04-2008, 09:04 PM
2002 SS's Avatar
same here shift around 6500
Old 11-04-2008, 09:14 PM
wht01ws6ta's Avatar
Yeah I shift around 6500 too. In my case with a stock bottom end on a 112 + 4 degrees of advance ground in there is no need to shift higher than that . Peak HP is at 6000 for me.
It sounds like you have a little too low of a gear IMHO. Have you ever scanned or logged it to see what your RPMs are really at?
Old 11-04-2008, 09:38 PM
when me and my buddy did logs on hp tuners, it said i was shifting around 6700 rpm. tach read around 7k. my cam is 232-234 595/598 on 112 +2. i'm not sure but i would think the trap speed should be in the high teens.
Old 11-04-2008, 09:44 PM
ls1chris's Avatar
with my v2 i was shifting at at 67-6800 and was getting around 112.5mph.I lowered my shift points to around 64-6500 and i get 114.8 mph now and occasion 115.xx I am cam only in my car though.
Old 11-04-2008, 10:15 PM
i am told i had ported 5.3 heads. i do know they are 5.3 heads for sure though because of the casting numbers. thats basically what i get is 114-115 but if i had good heads...SHOULD be 117-119. alot of people cam only run the same mph as i do but i they seem to hit low 12's as i hit high 11's
Old 11-05-2008, 06:19 PM
bad6as's Avatar
mine on a 110+3 peeks at 6200-6500
Old 11-05-2008, 08:18 PM
blown03mustang's Avatar
+1 same here
Old 11-05-2008, 09:49 PM
what does your factory tach read when you shift?
Old 11-05-2008, 11:05 PM
sidewayz28's Avatar
i prob shift around 6500, rev limiter is 6700. I think im guna set the limiter to 7k and let it rev a bit more. But im running 243s and a 90/90
Old 11-06-2008, 06:46 PM
it would be nice to have a fast 90. i heard the touquer responds very well with it
Old 11-08-2008, 12:01 PM
wht01ws6ta's Avatar
Yeah I think it does, more than 75rwhp increase when I swapped to a Tv2 and stock 243 heads, had the fast 90 before and after the swap.
Old 11-08-2008, 12:41 PM
sidewayz28's Avatar
nice, we basically have the same set up and made very close numbers. are they mustang dyno#s?
Old 11-08-2008, 09:47 PM
wht01ws6ta's Avatar
No they're dynojet so I guess if you have mustang #s yours are a good bit stronger. It was 100.6 degrees in the shop the day I had it dynoed though I guess my numbers will be lower now that I have a 9 inch...time for some more go fast goodies! And finally time to take it back to the track since I don't have to worry about breaking the 10 bolt!
Old 11-09-2008, 02:20 AM
sidewayz28's Avatar
mine too just put a th400 in it
Old 11-09-2008, 09:31 AM
bad6as's Avatar
mine made 390 hp and 360 tq on a mustang dyno threw a ls7 clutch, pst drive shaft and a 9" with 3.90s. at 3675 lbs i went 11.92
Old 11-09-2008, 10:20 AM
GregWS6&z28's Avatar
6400-6500 for me I believe
Old 11-15-2008, 10:38 PM
i am guessing your car does 10's on the 150 shot. what does she run n/a?
Old 11-16-2008, 09:31 AM
11.5-11.6 na
