Where to go from here.
Just like the topic said where do i go from here with building power. I have the traction and a RPM built stage 5 waiting on the stocker to bust so where should i be looking to pull more out of the old girl. The engine has around 95K on here now and other then the mods listed below is bone stock. I had planed on swamping out the LS1 manifold and TB to a FAST 90mm but now i am not so sure.
TTI 60 trim, 60lb injectors, snow meth kit, patriot springs, mild LSA 115.
You tell us, do you want to go 402+? You should be able to get decent boost with that setup on a larger-displacement motor that is forged. With those injectors, depending on what's feeding them, you'll be tapped at 600whp with 100% duty cycle. What kind of fuel setup do you have?
Right now i am trying to get as much as i can out of the little 60 trim and keep her close to stock cubes. Some day in the future i will go throw and rebuild and beef her up a bit but right now my goal is to break the 500 mark on pump gas while still keeping her on the mild side.
Not sure what you've got as far as a cam, but I know with turbo applications, a cam can go a LOOONNNGGG ways! Something with a bit more duration, with very little overlap will get you there. Just look for something in the upper 220's, low 230's on a 114-116LSA. Will still spool like a madman, and will make a grip more power.
The TTI 60 trim only put down around 420hp 510torque on 10psi with only the 60lb injectors. Its a great kit if you hate lag but as you know its a very small turbo for the size of a LS1. I dont think i will pick up 80 horses from 2 more pounds of boost with the meth and the mildish cam and springs.
