lt-1's and head gaskets
I have had two lt1 motors in my car one with a 175 shot of nitrous on stock head gaskets at 154,000 miles. No head gasket issues. But i have never had an issue bleeding my coolant system and or overheating. I think that is a big cause of head gasket failure. These engines are picky and you kinda have to know what your doing when working on them or else your liable to cause more damage.
The iron head motors is is VERY VERY rare to pop a head gasket. Aluminum has two things working against it, first is the different expansion rates of the iron block and aluminum head causing the gasket to be caught in a little fight between the two ever time it warms or cools, second if overheated badly the OEM aluminum heads can loose hardness in which case it has a hard time holding a gasket and most people do not realize this and just keep reusing the heads that are no longer hard.
If well cares for though they are not particularly prone to head gasket troubles. It is unny the way the internet blows some things out of proportion and in other cases actually hides problems because enough people deny them that it can't be true.
