Building LS2 Stroker - Need Help!!!
Building a 402 - LS2 stroker for my sandrail and need some help finishing the build. I'm not sure what Cam and injectors to use so I was hoping you guys could help out. I'm trying to get 570whp/575wtq - The more wtq the better.
Motor Specs:
- Caliies forged crank and rods
- Compression Ratio: 10.5:1
- CNC 243 Heads - Intake 2.000, Exhaust 1.550
- Fast 90MM w/ GM LS Performance Intake Manifold w/injection
- Cam ?
- What size injectors ?
Which is better ?
- GM LS Performance Intake Manifold (#88958675) or Truck Intake Manifold
Thanks in advanced
Motor Specs:
- Cam ?
Which is better ?
Thanks in advanced
I wanted to try and stay away from turbo or supercharger because of the budget
What do you think would be the best cam ? Remeber this is for a Sandrail and I need to get every last bit of torque I can out of this 402.
Any thoughts on the intake - LS Performance Intake Manifold (#88958675) or Truck Intake Manifold
Thanks,
Thanks,
I could be wrong but I am thinking you are going to need aftermarket heads and more compression to get close to your target numbers. That and all of the premium add ons anyways...
