whats my comp ratio? -32cc
3.622 stroke,stock, 6.125 rods, -32cc pistons. 853 ls1 heads think they are 68 cc stock..?,, and a 4.005 bore..i look on here could find a comp ratio chart..thanks..
LS1Tech Premium Sponsor
The info you've provided, assuming the piston is out of the hole .005", nets you 7.80:1 SCR.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
thanks that was fast.. i found a comp chart ,, it was giving me just about near the same answer as u did.. thanks. dang that is low.. what kinda boost u think i could run on 93 octane?..
That's VERY low. Do you already have these parts? Or are you still shopping. I'd try and get some more compression in it in most cases!
__________________
