Upgrading rod bolts, should I replace rod bearings??
Im Upgrading to some ARP 2000 rod bolts on my 67k mile LQ4 with a stock bottom end. Is it good practice to replace the rod bearings with a quality set? If so, whats a good brand, pn???
Thanks,
Chris
Thanks,
Chris
When you change rod bolts, you should have a machine shop resize the big end of the rod to adjust for the different clamping force. Some people get away without doing it, others don't and spin a bearing. What year is your lq4? I've got a set of 05+ rods with arp 2000 bolts already installed & resized........pm me if interested.
Yeah, Ive heard that the Katech Rod bolts are the way to go because theyre equal weight and work without resizing the rods. Ive heard of many using the ARP 2000's with no problems, Im not afraid to dig in and replace them.
If It does end up spinning a rod bolt, it equals a little frustration up front, and then a Forged 408 stroker in the future!
