Need advice trouble shooting codes
Old 11-13-2008, 07:38 AM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
Default Need advice trouble shooting codes
My T/A finally threw the SES light. The car sat for a few days and the SES light went off when I started the car. I drove it for two days and the SES light came back on.
Scanned the car last night. The codes were the ones for the front O2 sensors which I will replace tonight. Given that they are the orignal ones, I'm not surprised.
However, the other code was air in fuel tank. I've replaced the gas cap with a new locking one and still get that code. The seal on the new cap looks good. The seal on the old cap was bad.
What else can cause air the fuel tank?
Thank you.
Old 11-13-2008, 07:49 AM
69LT1Bird's Avatar
What code did you pull, its too much hassle to go looking for the code, if you know it, post it.
There is a sensor on top of the sending unit that measures pressure in the tank. Check that, you have to take the tank down to physically check it or get a schematic and a meter and check the outputs to the PCM to see if they are still within specs.
Old 11-13-2008, 09:28 AM
Tuner@Straightline's Avatar
It could also be anything that has to do with the EVAP system, I'd guess it's the selinoid.
Old 11-13-2008, 09:40 AM
The evap code was p0135.
Thanks for the tips.
Old 11-13-2008, 10:01 AM
2001NBMZ28's Avatar
That's not an EVAP code, EVAP would be P0440, P0442......
Old 11-13-2008, 01:14 PM
hmmm...after I change the O2's etc I'll get it rescaned...thanks for the heads up I was going by what the guy at the parts store told me.
Old 11-13-2008, 01:42 PM
2001NBMZ28's Avatar
If he was wrong on the EVAP code I wouldn't trust his diagnosis on the others either. If you're throwing codes for both precat sensors simultaneously it could be an indication of something else going on, for example running lean on both banks, and the 02s are fine.
Old 11-16-2008, 02:16 AM
Replaced the O2's today and cleared the codes. After 50 miles no SES.
