Texas Emissions Questions
Old 11-14-2008, 06:56 PM
93Z2871805's Avatar
Default Texas Emissions Questions
Does anybody know, have an idea of what it takes to pass emissions testing on pre-96 vehicles in Texas. I'm planning on moving back to Texas in the Austin and DFW areas and I want to be able to use my 93 Z28 as a DD. By the time I move the car is gonna be a 383 with 30lb injectors and a 255 walboro, 54mm TB, fully ported heads with 2.02/1.6 valves, true dual exhaust, A4 w/2800 stall, 3.55s, and a 112LSA .525/.545 lift 231/239 @.050 duration. If I have to leave the AIR system I will, if not it's gone. And I wanted to get rid of the PCV and EGR. Of course the tune to support mods. Can some LT Texans help me out with some tips? Thanks.
Old 11-14-2008, 08:41 PM
93Z2871805's Avatar
Any takers?
Old 11-14-2008, 09:10 PM
Counted Out's Avatar
There's a whole section for Texas members. Near the bottom of the main page. Someone there will know.
Old 11-14-2008, 09:24 PM
Moderator
BizZzatch350's Avatar
Austin and Dallas require smog testing, it wont pass. You would need cats and a smaller cam.
Old 11-14-2008, 09:25 PM
$O$OE's Avatar
can u do a crooked smog?.
you know pay a lil more of regular price smog and your car can pass with flying colors??
Old 11-14-2008, 09:27 PM
Moderator
It's gotten harder, state troopers have really cracked down on it. Not like how it was before, I'm sure you still can though, right shop.
Old 11-14-2008, 09:29 PM
$O$OE's Avatar
ok sounds good, yeah i know they crack down on that, i just moved out here from cali so i was wondering if its possible because i know out there it is, u just need to know the right people/shop.
Old 11-14-2008, 10:22 PM
93Z2871805's Avatar
I was thinking about putting a serious electric air pump in the trunk and blowing a serious volume of air into the muffler or the cat to try and dilute the emissions.
Old 11-14-2008, 11:29 PM
$O$OE's Avatar
just pay the price and get it done the illegal way..
Old 11-15-2008, 12:20 AM
Bad_tx_Z28's Avatar
well i happen to live in a saftey only county. its the only way i can get my car inspected.
Old 11-15-2008, 12:28 AM
texas94z's Avatar
It def wont pass in emission counties in texas. you better register in a non emission county to get a safety only sticker.
Old 11-15-2008, 04:45 PM
93Z2871805's Avatar
What are some safety only counties around the DFW and Austin areas? I do have an address I can use in temple, it's by Ft Hood and Belton.
Old 11-15-2008, 06:29 PM
Bad_tx_Z28's Avatar
im in navarro county. Its about an hour south of dallas.
Old 11-15-2008, 06:32 PM
$O$OE's Avatar
wtf is a non emission county?? no smog need to be done in that county?
Old 11-17-2008, 01:45 AM
93Z2871805's Avatar
A non smog county is apparently just a safety inspection, no tailpipe at all. I was looking on DMV.org and they give you a map of counties that are emissions counties and they show the county that emissions tests and what method they use. Apparently there are only like 10 counties that actually do emissions checks and they are around el paso, houston, and dfw. Form what I get from it is, those are the only places that will smog check a vehicle. Also, I can look forward to my car aging because after its 24th b-day I wont have to get inspected again.
Old 11-17-2008, 02:16 AM
69gto96z's Avatar
What county will you be living in? If you take the car to get inspected in an emissions county, it doesn't matter where the vehicle is registered. It will get an ASM dyno test. All you have to do is find somewhere to get it inspected in a non-emissions county. The only way an inspector will know what county the vehicle is registered in is if he happens to look at the address on the insurance. And that only tells the city, not the county. Plus, an emissions test is 39.75 and a safety only is 14.50 You may have to leave the emissions equipment for a visual check though, depending on how hard the inspector looks at it.
Old 11-17-2008, 07:20 AM
$O$OE's Avatar
its confusing to me since i just moved here from Cali and its a different system from out there to here, thats why im confused.....i live in keller dont know if thats a non emission county...
Old 11-17-2008, 07:24 AM
$O$OE's Avatar
and how often do the cars need to be inspected here in Texas?
Old 11-17-2008, 07:58 AM
SSwt00SS's Avatar
yearly, unless you buy a new vehicle. when you buy a new vehicle the inspection is good for 2yrs, but then yearly after that. vehicle registration in yearly as well regardless if its a new vehicle or not...
Old 11-17-2008, 08:01 AM
SSwt00SS's Avatar
any OBD I car (pre-1996) with be subjected to the sniffer (mandatory by law). any vehicle with OBD II is not required to be sniffed. they plug into the OBD II port leave the car idleing and do the test that way. however some shops go ahead and sniff OBD II cars. choose youre inspection station wisely...
Quick Reply: Texas Emissions Questions
