What color FRC's?
What color FRC's?
help me out here I'm going to get a set of FRC's and do them myself, which color should I paint them? My T/A is red, should I paint them red to match the car color or should I go with DupliColor's ANODIZED RED...before the negative feed back on this color comes in let me say I did a test on some piece of plastic and going by the instructions..using the special base coat(it gives the paint reflection) for anodized paint it came out very sharp
what do you think?
what do you think?
Re: What color FRC's?
I don't care about the color, but Duplicolor is crap, IMO. When I used it on my calipers, it reacted with itself and wrinkled horribly. It looked like the skin of an alligator! So the trick is to not give more than 5 minutes between coats. When I had to do my FRC's, I needed to find a paint that wouldn't react with Duplicolor because I had to let the first coat dry so I could put on the decals. A brand named Commercial Coatings did the trick, looks trick as well!!! I used CC ford red, and Duplicolor clearcoat.
I'd say black w/ red lettering, or red w/ black lettering. Anodized red would look pretty cool, what about powder coating 'em red? Just another opinion.
But, those are my two color scheme's. Basically, red w/ black, or vice versa.
. . . but Duplicolor is crap, IMO. When I used it on my calipers, it reacted with itself and wrinkled horribly. It looked like the skin of an alligator! So the trick is to not give more than 5 minutes between coats. . . .
I have had great luck with Dupli Colors 500* Engine Enamels.
I cannot possibly say enough bad things about Duplicolor white wheel paint,wheel clear coat, and High temp Silver. I used their wheel paint on my motorcycle wheels and followed the directions to perfection (even monitored the temp and humidity) and it did NOT go on the color the can stated and chipped off if you rubbed it too hard. I also used their "high temp" silver paint on my calipers and then clear coated them only to have it flake and generally look like ****. I did prep the surface and cleaned it with the proper cleaner.
Does this apply to the rest of their paint?
No, because I used their high temp black paint on a rear end and on and engine and it help up pretty well.
Just wanted to let you now my experiences with the stuff.
