Lt1 junk goes 11.20's na
Old 11-16-2008, 08:06 PM
BADHAWK51's Avatar
Default Lt1 junk goes 11.20's na
I'm a little late posting this but anyway went to the track with Speed Inc on 11/1 and the car was running 11.2's na on a soft sixty 1.605 @ 119.97 mph I'm pretty happy with the car I'm just hoping I can get the car to 1.4 sixty come spring with a few changes so I can run with that guy Larry and his 396 junk
Here's a crappy vid from a camera.
Old 11-16-2008, 09:16 PM
Z8'S's Avatar
Hoy Crap!!!!! That old guy in the blue car kicked your ***
J/K
Once you get that thing figured out it is gonna fly.
Old 11-16-2008, 09:53 PM
z28rob18's Avatar
wats the details on the 383? heads cam specs? size shot that ur gonna run?
Old 11-17-2008, 06:47 AM
LS1 SPEED's Avatar
cool buddy... it's been a long time coming, but it will get in the 10's NA with the planned changed and be more of a driver as well.
Jeff..you know there is no harm slapping an old guy right?
Old 11-17-2008, 11:56 AM
Z-RATED94's Avatar
What's up with that? He calls your 396 junk, and you want him to slap the old guy? I'm confused as usual.
Old 11-17-2008, 03:16 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,222 Likes on 779 Posts
LS1Tech 10 Year
They are all local friends.
Congrats Jeff. 60ft is just a matter of figuring out if the converter and gear are right, and what the suspension is doing (among other things). I'll get another car out to come out and try to wack the old guy in '09.
Old 11-17-2008, 03:45 PM
LS1 SPEED's Avatar
ha..he was already getting a hard time, so I stepped down. I can't complain since he was a big part of my junk 396
Old 11-17-2008, 03:55 PM
BADHAWK51's Avatar
Z8's Hoy Crap!!!!! That old guy in the blue car kicked your ***
J/K
Yes you got me good on that run Chris but I'm coming for ya.
LS1 Speed Jeff..you know there is no harm slapping an old guy right?
Larry with all the crap he was giving me that day at the track.
Pro Stock John Congrats Jeff. 60ft is just a matter of figuring out if the converter and gear are right
Thanks John, I think we might have it figured out. I think suspension is fine more of the converter than anything.
Old 11-17-2008, 04:00 PM
LS1Tech Co-Founder
LS1Tech 10 Year
Yah if the car is dead nuts consistent it might not be enough or the right converter. What do you shift that beast at?
Old 11-17-2008, 08:52 PM
BADHAWK51's Avatar
John, I'm shifting at 6700 but I think between first gear of the th400 and not enough converter is holding it back some. The car needs to sixty in the 1.4's like Larry's car to have the best chance of hitting 10's on nuts. The best sixty to date is 1.605
Old 11-17-2008, 09:03 PM
BADHAWK51's Avatar
The car has Brodix track 1 heads ported by RGR and the cam is a hydrolic roller somewhere is the 620 lift range don't remember the exact specs nothing crazy. I plan on hitting it with maybe 150 shot my fuel system won't support anymore than that for now and depending on this new converter I chose I may be limited anyway.
Old 11-17-2008, 09:29 PM
Z-RATED94's Avatar
That was just my sad attempt at some humor. I was there that day.
Old 11-17-2008, 09:35 PM
BADHAWK51's Avatar
Did we talk that day I'm terrible with names ? we need to get a bunch of the locals out come spring I'm done for this year.
Old 11-18-2008, 09:07 AM
LS1Tech Co-Founder
LS1Tech 10 Year
If you are not spinning, you need more converter. my 10.92 was with the 4800 Fuddle, the new converter is a 5500 and the car will probably cut a high 1.3 if the new owner pushes it.
Old 11-18-2008, 09:22 AM
z28rob18's Avatar
that a nice set up wat u think its goin to run on that 150 shot if u get that 60' better?
Old 11-18-2008, 10:35 AM
LS1 SPEED's Avatar
PSJ..it will go in the 10's come spring
z28rob18..The car would go low 10 teens I think with a 150 shot and decent 60ft.
This car is not a gutted car and weighs 3500-3600 with driver if I recall correctly.
Old 11-18-2008, 10:39 AM
LS1Tech Co-Founder
LS1Tech 10 Year
3500 + a nitrous converter will struggle to hit the 10's. I'd run at least a 4500 stall up to a 4800/5000 and you can still spray it. My last converter was a 5500 and that would been sick on a big shot, but it still went 9.9 on a 100 dry shot and was very manageable. Personally set up the car up for strong NA, and then spray a little.
Old 11-18-2008, 11:20 AM
registered user
ScreaminRedZ's Avatar
Great run! That LT1 moves out!
Old 11-18-2008, 11:26 AM
gotjuice?'s Avatar
Awesome,that lt1 moves
Old 11-18-2008, 01:30 PM
LS1 SPEED's Avatar
we got it covered John
Quick Reply: Lt1 junk goes 11.20's na
