Side of DR's getting sliced by inner fender
Old 11-18-2008, 01:49 PM
TurbopigB4C's Avatar
Default Side of DR's getting sliced by inner fender
The inner lip on the rear fender is digging into the sidewall of my Mickey Thompson 275-60-15s when I hit bumps does anyone know a good way to roll the inner edge without hurting the rear fender?
Old 11-18-2008, 01:52 PM
porksoda's Avatar
Rent a fender roller
Old 11-18-2008, 02:05 PM
I never knew they made such a thing thanks ill try and find one
Old 11-18-2008, 02:11 PM
jetlag's Avatar
There was a guy on here renting his..also on ls1gto.com.
Check around your local performance shops, sometimes they have one.
Also when you do it be careful that the fender is not cold and don't go too fast or you will crack the paint.
Old 11-18-2008, 04:55 PM
LS1CMR's Avatar
get a set of bump stop spacers from slp they are like 40 bucks
Old 11-19-2008, 04:35 PM
jrob56's Avatar
mine does everynow and then on my 315 nittos but its a real shallow cut and im worried about cracking the paint if I roll them...
how would bump stop spacers help the inside of your fender from slicing into the tire?
Old 11-19-2008, 04:42 PM
SLICK_LS1's Avatar
I had the same problem when I first put my 315s on. But what i did was put my stock springs back on and now it clears everything perfect. Also i like the look better
Old 11-20-2008, 08:46 PM
camarojunky74's Avatar
try an aftermarket panhard and lca's that fixed it for me
Old 12-09-2008, 12:44 PM
69TA's Avatar
I have a fender roller for rent
PM me if you still having slicing problems.
