Are there any sponcers on here that will degree a cam on a cam and head install?
Are there any sponsors on here that will degree a cam on a cam and head install?
I will be ready in the next couple of weeks to have my heads and cam installed and I would like the cam to be degeed in during the installation. The cam I ordered will work best if it is degreed in instead of just lined up dot to dot. I will be buying a single adjutable timing set for the install also. Also please send a pm with price for the install of the heads and install and degreeing the cam. I will supply all of the parts.
most people when they install a cam they just line them up dot to dot. The only way you can degree a cam is to use an adjustable timing set also. So if you use a reg. ls2 timing set or chain you cant degree the cam.
http://en.wikipedia.org/wiki/Special...search=sponcer
relax, just a little joke.
