Bolt on/Stalled guys what kinda times are u turning?
12.49 @ 107mph w/ 1.69 60ft (7.91 @ 85mph 1/8th) 3364lbs
SS3600, PS Longtubes, Moroso CAI, CPT Pro Race 4l60e, 3" true duals, ls1 alum DS, BONE STOCK 3.23'S, BONE STOCK SUSPENSION (minus !swaybar).... theres prolly a few small mods i forgot about but thats the big ones
next year hoping for a 3200lbs raceweight or less and a 12.2x pass stock gears and suspension...
1996 Z28 - Comp cam, Comp 26915 springs, 1.6 Comp Magnum RRs, MSD Ignition, Wrapped Hooker 1.75" LT, 3" ORY, dual 3" Cutouts, Aluminum Drive Shaft, 2500 Stall Converter; Deleted the EGR, AIR and AC... and the PCM for Less tune... Being pushed by heavy 20" steel rims that the kid had on it when I bought it... they're wrapped in El Cheapo Falkens I got over at Sears...
Last week when the temps and humidty were pretty close to prime runnin' she laid down the following on our best run:
1.91 60'
5.31 330'
8.14 ET
86.96 Mph
I had hoped to put the MT Streets on a set of stock salad shooters I had picked up, but that's not going to happen this week, so we have one more weekend on the scuzz... After that, I expect to knock that time down by 2/10s and it's coming right out of the 60'. Next week I'm buying the 3600 Stall and we'll take that down another couple of 10ths...
1.91 60'
5.31 330'
8.14 ET
86.96 Mph
12.99@102.11 1.72 60'
3440 w/me, still has stock air filter assembly n paper filter n stock elbow. Stock shocks with 2 coils cut off stock springs. PS longtubes, H-pipe, Bullets TD, VIG 3200, Hurst linelock, LS1 Ds, SFCs, LCAs, T/A cover, 3.73s, Fat n skinnies, and Madztune. Shift points are wrong since I bounce off limiter between 2-3.
Times were ran on 85 deg day so I'm hoping with the right shift points, Cai, 1LE elbow and a cool night when the track opens back up I can knock off another 2-3 tenths. I hope to have 1.6rr and new springs as well, so that should be good for another tenth. My goal is to hit 12.49, which I think is possible.
