Pulling SES Codes Manually without a scanner?
Old 11-27-2008, 02:37 PM
ORedRoc4's Avatar
Default Pulling SES Codes Manually without a scanner?
Is it possible to get the SES codes without a scanner or OBD reader or tuner? Reason i ask is i have no way of getting my codes read for free or cheap here in the UK. If i could i would just go to Autozone to get it read, but im not in the states... Locals want $120 just to pull the codes
I have before pulled codes on other cars manually using a jumper on the OBD port and just counted the flashes the SES/CEL flashed and refered to the manufactures code book.
Its a 96 obdII non california car, and i can delete the code by removing battery power. When the car is turned on after that the car runs great and strong for a bit, but after about 15-20 miles the SES light triggers and i start to get a really bad stumble when crusing in 6th and trying to gain speed, or any time a heavy load is on the motor. when going WOT at about 3K+ the car pulls relatively normal... o2's is just a guess but i really dont get worse gas mileage, but i want to know for sure whats triggering the fault... Anyone?
-justin
Old 11-27-2008, 03:31 PM
impaled's Avatar
-justin
not on OBD2. the jumper works on OBD1 only. pick up your own scanner so you can pop it off. i paid like $80 for mine here in the states and they have cheaper ones.
you have deleted several things that will throw codes in you sig. have they been tuned out?
nevermind i see that that is on your 1995
Old 11-27-2008, 05:54 PM
ORedRoc4's Avatar
No, this is in my Bonestock '96 Z28...
Do you have any references for the $80 scanner (Ebay, ls1tech vendors, etc.)? I will buy one right now lol.
thanks!
-justin
Old 11-27-2008, 06:06 PM
impaled's Avatar
pm sent
Old 11-27-2008, 09:21 PM
Drumer919's Avatar
My scanner cost $10 and it is a data-logger/tuner too. just buy a OBD2 to USB adapter on ebay and download one of the many free programs (or even buy one of the top end ones)
Old 11-27-2008, 10:02 PM
1996firebirdformula's Avatar
Autozone scans and clears em for free. just heads up
Old 11-28-2008, 01:14 PM
ORedRoc4's Avatar
-justin
Old 11-28-2008, 01:42 PM
impaled's Avatar
that is nice, but i carry my reader with me just in case something pops up and if it does i can tell when/what i just did. although if you always had your laptop with you it would be nice.
Quick Reply: Pulling SES Codes Manually without a scanner?
