Pro Mag valve lash
Old 11-29-2008, 04:50 PM
BigDB's Avatar
Default Pro Mag valve lash
Z has a Lt1 in it. The engine hasst been started in 3 weeks and im buttoning up a cam install. Im setting the pre load for the valve train with the Pro Mag rockers from comp. They say to tighten until the push rod has resitance then add another 1/2 turn and tighten the lock. Now the lifters are bleed down and im thinking that when the lifter pumps back up with oil its gonna hold the valve open. Am I wrong? Should I go back and only tighten 1/4 turn?
Old 11-29-2008, 04:59 PM
lt1z28camaro's Avatar
I went with 1/2 turn, runs great for me..
Old 11-29-2008, 05:18 PM
SoxXpupPeT's Avatar
i did mine quarter of a turn. mine are NA and make a very very tiny bit of chatter. a half a turn should be good
Old 11-29-2008, 05:28 PM
Fire67's Avatar
Alot of people have issues with valve adjustment because they do not pump up the lifters before adjusting the rockers. I always have the plugs out, and take the rockers off of the stud. Then turn the motor over until I see oil coming out of the pushrod tip. Then I install and adjust the rockers one at a time in sequence. Never failed me yet. I also use 1/2 turn past a little resistance.
Old 11-29-2008, 09:35 PM
James Montigny's Avatar
See attached documents.
File Type: pdf
File Type: txt
Old 11-29-2008, 09:56 PM
SoxXpupPeT's Avatar
i should of mentioned that i turn my engine over afew times to make sure the lifters have oil in them so that when you set valve lash there all where there supposed to be
Old 11-29-2008, 10:43 PM
camar0corey's Avatar
I actually went a full turn this time with the promags. I'll let you know Monday when I try to fire it if they ended up being too tight. I think I mashed two due to spinning the thing higher than I should have been.
Old 11-29-2008, 10:46 PM
buffman's Avatar
I'd just go by there recommendations so the car can be started. Once the car is startable do a dynamic lashing. set all to 1/4 or 1/2 Turn. Call it a day. Make sure those allen set screws are tight. Dynamic is a lot more accurate. Loosen poly till clacking. Tighten (i use fingers for precise control) until quiet. Set preload. Hold poly then get that set screw tight. Done. Move on to next rocker.
Old 11-29-2008, 11:41 PM
If it makes bad noises or looses power up top, you're probably too tight and losing cyl pressure at high RPM.
So many people drive around like that and never known it.
Old 11-30-2008, 12:14 AM
SoxXpupPeT's Avatar
you could run the car and adjust them. try a 1/4 turn and see how it feels. mine feels real smooth. the higher the RPM the smoother it gets its beautiful
Old 11-30-2008, 12:47 PM
leadfoot4's Avatar
I agree!!
FWIW, ARP says to tighten the set screws on their poly locks to 22 ft/lbs.
Old 11-30-2008, 12:50 PM
1redta's Avatar
Default re
sorry to high jack but when using the ARP's to replace the comp polylocks what size shoulder do I need for the 7/16th CC rocker? TIA Art
Old 11-30-2008, 12:58 PM
AChotrod's Avatar
LE told me, Make sure the rockers are adjusted to 1/8 past zero lash on my set up.
Old 11-30-2008, 01:15 PM
SoxXpupPeT's Avatar
only 1/8th ? thats probably because your running a hefty cam, so you dont lose power up top
Old 11-30-2008, 02:39 PM
StealthFormula's Avatar
^^Thats what I was told and did as well. They make noise but the car runs awesome.
Old 12-01-2008, 01:02 PM
leadfoot4's Avatar
Not sure what you're trying to find out...All polylocks are pretty much the same diameter down the shank, and they seat on the trunion of the rocker arm. The only difference, especially when talking about the ARPs, is the size of the hex where you place the wrench. The APRs have a 9/16" hex, and most of the others are 5/8".
Old 12-01-2008, 08:18 PM
1redta's Avatar
Default re
the poly lock come in sizes .550 .600 .650 and .750 The comp pro mag 7/16 stud NSA uses the .550 shoulder
Old 12-02-2008, 07:38 AM
leadfoot4's Avatar
I guess you learn something every day... Would the larger diameter locks be used on small block Chevy rockers, however?
Old 12-02-2008, 08:40 AM
1redta's Avatar
Default re
i fyou go to comp cams website you can find it here
http://www.compcams.com/technical/Ca...106-07/276.pdf
Quick Reply: Pro Mag valve lash
