What cam to run with the LQ9, L92s, L76.
Old 11-30-2008, 01:14 AM
1meantransam's Avatar
Default What cam to run with the LQ9, L92s, L76.
I'm sure this has been asked but i did a search on it and cannot find anything useful. Have asked several people as well and some don't know, others won't tell me.
I'm doing a 6.0 Iron block (LQ9) with CNC L92 heads, and the L76 intake manifold. i've been trying to find out what cam to get for it and was pretty well set on a 236-240 608 111, but have been told it's way to big. I was told to go with a smaller cam to make best power but I'm not sure on which specs to get. i would like to stick with a cam i can use my small stall with as well. any help on which cam to go with?
Old 11-30-2008, 03:42 AM
the_merv's Avatar
That Cam is a little bigger than most of the ones that have been going into the 6.0l size Engines with L92's.
Old 11-30-2008, 03:56 AM
ringram's Avatar
More split, less duration and probably more separation in lobes.
Old 11-30-2008, 10:52 AM
RickClarke23's Avatar
I have a 6.0L with WCCH stg 2 L92's and a ported L76 intake/TB. I am running a Custom Cam 231/243 .617”/.624” 114LSA +4 advance It has not been Fully tuned and only has around 240 miles but seems to run STRONG with lots of low end. This cam was spec'd for nitrous in mind (200 Shot). However with your Small Stall i would probably choose one of the 228/232's that many vendors cary for the L92. Synergy has one
Old 11-30-2008, 11:06 AM
yeah i was debating a 228 area cam, i just sold my old one which would of been perfect. i would go with Synergy but i can get CCs at cost and i'm on a major budget right now. otherwise i definitely would...
Old 11-30-2008, 11:10 AM
Ryans_pewter_ss's Avatar
I'm running 228,232 600/630 112 lsa, i'll have dyno numbers soon. Car feels real good! I went with the gmpp intake though. Guess we'll see how it does.
Old 11-30-2008, 11:33 AM
when are you getting it dynoed?
Old 11-30-2008, 01:10 PM
Just about done with the nitrous, prob within a week or so. I am gonna dyno it n/a and with a 150 shot. I'm gonna run the local 1/8th on the 7th, i'll let ya know the times if it goes good!
Old 11-30-2008, 01:20 PM
yeah i'll be putting mine together in about a week to so that will be good. i saw a truck out at Bay Town last sunday run a 12.4... has same setup and it was a full size silverado, definitely gives me good hope haha.
Old 11-30-2008, 01:44 PM
bottlefed370's Avatar
Very interested in well to see what your dyno #s are. Im not hi-jacking the thread but how much bigger than a 228/232 cam with say a 4400 stall in a 377 and alot of nitrous?
Old 11-30-2008, 01:46 PM
Really pisses me off i missed most my cam seminar in school. the one part of school i wanted to learn the most and i missed it.
Old 11-30-2008, 02:33 PM
xdanny510x's Avatar
im running a 230/244/612/598/114 lsa in my l76 408 iron stroker
Old 11-30-2008, 02:44 PM
Disturbed Bird's Avatar
wait till the fast L92 intake comes out to take advantage of the higher flow in the upper rpms that mani is good past the low 6000's range.
Old 11-30-2008, 06:15 PM
dca1042's Avatar
ive just fired my new l98(6lt alloy,l92 headed,l76 manifold),with 224/230 114 comp cam,it sounds sweet,will finish tuning this week and post some numbers.car has 3600 stall th400,1.75" trys,3"duals,3.73 9".
point to this exercise your trying to achieve,is,drivability,torque,and fun factor,
dont over cam your large port(l92 style)heads,tou will lose the torque and have to rev it.
especially with a small stall.
cheers dave,
Old 11-30-2008, 11:05 PM
the_merv's Avatar
How is that one working out for you?
Mine is a 243/247, .621/.612, 114+3 LSA
Old 11-30-2008, 11:45 PM
cheers dave,
Definitely post those numbers up i would like to see what you put down. i'll probably go with that same came you have.
Old 12-01-2008, 09:05 AM
1.8t's Avatar
I have an almost identical cam in mine. Mine is a 231/243 .617”/.623” 115LSA +4 advance
Old 12-01-2008, 12:29 PM
How well does that 231/243 cam work for you? I want a cam that has alot of lope to it but can handle a big stalled nitrous car.
Old 12-01-2008, 12:36 PM
1.8t's Avatar
It has worked great for me. It is much faster than my 1/4 mile time/trap indicates. There was a lot of crap that went wrong on the run in my sig, but the car has low 11's and 127+ mph in her once I get everything ironed out. I have 7500 miles on this cam'ed setup and she hasn't missed a beat. Very driveable.
Old 12-01-2008, 12:48 PM
KurtRardin's Avatar
I've really had my eyes on the Lunati Voodoo 60512 232/238 .599/.601 113LSA. Not a spring slammer, good power under the curve, and a NASTY sound. I am even thinkin about this cam in a 408. Oh and they're cheap too!!
Quick Reply: What cam to run with the LQ9, L92s, L76.
