HPT tune for bolt on MS3??
does anyone have a HPT file for a bolt on MS3??? Looking for something to get me started...
MS3...112 LSA
LS6 heads
hooker long tubes
ORY
LM1
Ported TB
M6
3:42's
MS3...112 LSA
LS6 heads
hooker long tubes
ORY
LM1
Ported TB
M6
3:42's
It's up to the people who have HPtuners to put that on there. The only reason I use it is for the stock tunes. Which half of the stock tunes aren't entirely stock.
If you have HPtuners, just tune the car. Don't worry about someone else's tune that may be as far off as the one you have now.
Besides that...you should never flash in a tune you don't KNOW is what you THINK it is...download a few "stock" ones and compare them all to each other to make sure it's actually stock...then work from there. Thats why you have the software.
I could post something that might get you running. It's not from an MS3 though. What size injectors are you using? If you flash someone else's tune, be sure to make sure that the injectors are scaled properly (Improperly scaled injectors are one of the top ways to ruin an engine).
