Y-Pipe struggle and questions!!! pics
I tried to install my pacesetter Y-pipe today and thought I did a decent job until I tried to put some parts back on. I cannot get the passenger side hanger to even come close to linging up with the bracket on the y pipe!!! I also cannot get the brace thing to clear the y pipe where its suppossed to connect to the cat back!! any ideas? can I just leave this off, because the y pipe itself is as stable as can be
The ground clearenace looks fine to me. Like I said, the y-pipe is strong and looks to be even.
Here is the passenger side hanger, it doesnt even come close to lining up as you can see.
and this "brace" hits on the y-pipe collector and can be put back on! did I do something wrong or can I just leave all this off?!?
thanks this is what I wanted to hear. The brace is paper-thin metal anyways, I couldnt imagine it doing a whole lot of anything. Is everybody else doing the same?
i put the side hanger in the from the other direction and made it work like that. had the tunnel brace on for the first week but got tired of hearing it and the y-pipe make a growling noise so i pulled it off.
no i was talking abou the tunnel brace that runs under everything lol. yeah the other bracket just get rid of. or do what i did and fab something up. i welded a plate with a nut welded to it to the under belly of the car and bolted a hanger through it. worked out real nice. just make sure you take the carpets out or severe burning will occur
