unplugged o2's= high oil pressure??
Old 12-02-2008, 07:41 PM
grnmonster's Avatar
Default unplugged o2's= high oil pressure??
My Car has been misfiring someone suggested i unplug the 02's to see if it ran better ....it ran a lot better after unplugging them but my oil pressure went through the roof i mean like passed pegged...is that normal????
Old 12-02-2008, 07:46 PM
MTBSully's Avatar
probably just your guage getting messed up. Your o2s have nothing to do with your oil pressure becuase oil pump is mechanically driven and not related to the electrical system.
Old 12-02-2008, 08:11 PM
Smokinlt1's Avatar
Unless unplugging the 02s caused the idle to go up which in turn would increase oil pressure reading.
Old 12-02-2008, 10:03 PM
1994Z28Lt1's Avatar
sounds like an electrical gremlin
increasing the idle should not peg out the oil pressure gauge, hell a stock or even a high pressure oil pump shouldn't peg out an oil pressure gauge if it working correctly
Old 12-02-2008, 10:35 PM
Village Troll
SS RRR's Avatar
Reads like the sensor is not longer plugged in.
Old 12-03-2008, 05:05 AM
Smokinlt1's Avatar
Haha I didn't see the pegged part, guess I need to finish reading sentences instead of assuming. I assumed he meant his oil pressure went up.
Old 12-03-2008, 01:58 PM
Formula350's Avatar
If our car's PEG the gauge when it's unplugged, then it's possible he unplugged the Oil Pressure sensor and not the O2
Now, it's less likely on 94+, but on our 93's the oil pressure sensor is down on the oil filter adapter housing. Not behind the intake manifold like 94+. Though, after thinking about how that is setup, I don't think it has a long tail like the O2s do, and the sensor plugs right into the pressure sensor, so it would be less than likely anyone would unplug that by accident. [/ramble]
Old 12-04-2008, 09:01 PM
nasty96's Avatar
yea i'd say he unplugged the oil pressure sensor also.it will peg the gauge for sure
Quick Reply: unplugged o2's= high oil pressure??
