Power antenna -> whip antenna?
Old 12-03-2008, 09:09 PM
SeanT/A's Avatar
Default Power antenna -> whip antenna?
Anyone ever taken the power antenna out and had just a regular whip antenna in its place? Mine i slightly ben and doesnt want to go up and down all the way with out me making it do it. Annoying. Isnt there a replacment peice for it?
Old 12-04-2008, 07:12 AM
Ungrounded Moderator
WhiteBird00's Avatar
You can buy the replacement mast separately (PN 10256439) but it retails for $63 so you might not want to spend that much. Replacing with a fixed mast antenna is simple - just remove the old one and bolt the new one in place.
Old 12-04-2008, 09:41 AM
QWIK Z of OP's Avatar
https://ls1tech.com/forums/appearanc...r-antenna.html
Old 12-04-2008, 11:04 AM
SeanT/A's Avatar
Originally Posted by QWIK Z of OP
Nice! I guess I was looking in the wrong section!
Old 12-04-2008, 01:12 PM
Save the manuals!
wssix99's Avatar
If you decide to go with a mast replacement- I've been able to find them for less than $50. Instructions to replace are here:
https://ls1tech.com/forums/general-m...r-antenna.html
Old 12-04-2008, 02:21 PM
Wow! I can't believe that so many pictures are required to show how to do something so simple! Let me know when you're looking for a tutorial on checking tire pressure.
Old 12-04-2008, 02:27 PM
SeanT/A's Avatar
I havnt even looked at the motor or anything. I figured someone here had done this before. So now I know the easiest way.
Old 12-05-2008, 10:18 AM
lol!!
