427 + F1R....will it work out well with those cubes?
i want to go FI when my engine comes back. only prob is, I'm having it further bored to 4.125 from its 4.1 bore, and using a shorter stroke 4" crank. so it'll be a 428ci. its all I have to work with, i can't get a new engine built, this one i'm getting for free. i'm just paying for the machine work. its resleeved LS1 block.
how will a F1R do with this size engine? not gonna use 6 bolt heads either, just ported L92's with a ported L76 intake.
gimmie some opinions please. I would love to put down 900 rwhp. thats the goal.
also, where should I get the kit and keep my A/C. its a WS6 Trans Am that will only be driven on the street. full interior.
Thanks.
Thanks.
from my epxeriences with the f1a I'm having installed, I think that is about as big as you can go in a fbod while retaining ac etc...Hopefuly, mine will be done soon, so I can post some #'s with a 408 F1a with some L92 heads.
The F-1R with the f body bracket assembly will require modifying the radiator support to allow for clearance. The F-1R also requires a lot of power to turn it, which tends to cause belt slippage. For a street driven car, I'd go with an F-1A. Check out this CTS-V with an LS2/402 with an F-1A. The dyno graph is clear at the bottom. This car makes enough power that it broke the tires loose somewhere between 60 and 70 miles an hour an the car did several 360's on the highway for it's owner. This was with Nitto's on the rear, it now has M/T drag radials on it. http://www.exoticperformanceplus.com...Car.php?car=29
Here is our ProCharger kit price.
http://www.exoticperformanceplus.com....html?item=798 Bob
Thanks, we appreciate it!
So, will the 428ci be fine for the F1R. I can leave the current crank (4.125) in the engine and then with the new 4.125 bore it'll make it a 441ci. If those extra cubes will help turn the F1R, I'll just leave it in and save some money at the same time by not having to buy a new crank.
Whats the deal with belt slippage, is it simply going to happen with a big engine? Wnat can be done to eliminate slippage?
My goal is at least 900 RWHP, over 1,000 will be great. Full time use of race gas is just fine with me, as this will be a street car...but really only driven on weekends or special occassions. It'll be a show car inside and out.
Its not the size of the engine that causes belt slip. its the power use to turn the f1R charger. the head unit is maybe using 100 hp or more to compress the air which is all going though the 8rib belt.
so, whats the fix for use on an LSx engine? Zero belt slippage.
If you want zero belt slippage, you're probably going to need a custom cog setup designed. EPP has a preliminary one, but it is not for sale yet. Also, with ac on, you're going to have to figure out how to keep it from overheating in stop and go summer traffic (if there's still enough room to fit the condenser). Have people done it successfully on a street car before? Of course. But, there doesn't seem to be alot of blueprints out there for you to follow. You have to do the R&D on your own. This of course takes alot of time and even more $.
now I know why people just say to use a turbo. easier to make tons more power and keep it way streetable.
my mistake I guess. I thought the Procharger was a bolt-on kit and I could use the F1R.
so, is the F1A the biggest sc'er I can use with the bolt-on Procharger kit and keep a/c?
I have a lot of pictures at the above link that may help you out. To install an F-1C/F-1R will require modifying the radiator assembly, and you'll end up modifying the bracket to eliminate belt slippage. Bob
http://www.exoticperformanceplus.com...Car.php?car=12
i'm really needing to keep A/C though and keeping it full interior...and driving it on the road any time I want to. Not a drag car at all.
looks like turbo is the way to go, more power and more drivability.
how long does it take to modify the radiator assembly and the bracket? so, this isn't just a Procharger kit install using an F1R, with the modifying you mention, right? Its a major project, right?
