Correct ARP Headbolts?
are these the headbolts i need for my 95 lt1?
http://store.summitracing.com/partde...1&autoview=sku
thanks!
thanks!
Well i called twice and talked to two dif reps at summit and both said they'd work so if they dont looks like summit is sending me different ones haha. Ordered those and Mr Gasket head head gaskets today.
Yes those are the correct bolts. For $6 more I would suggest part# 134-3701 which is the same except for the fact they have 12 point heads which make them a little easier to install because it requires a little less wrenching in some tight spots under the cowl area. Just something I learned from doing it that may make things a tad easier for you.
Ya i was on the fence about the 12 points but just decided to go with the 6 point for some reason, oh well. can't go back now, they'll work. Thanks for the replies guys!
