where to buy hot wire kit for walbro?
Old 12-09-2008, 01:19 PM
STANG KILLA SS 2's Avatar
Default where to buy hot wire kit for walbro?
any help would be appreciated.
thanks
Cory
Old 12-09-2008, 01:45 PM
koolaid_kid's Avatar
Please explain what you mean by "hotwire".
That's what I used to do to my dad's 54 Ford when I wanted to go on a joy ride.
Old 12-09-2008, 02:19 PM
its a wire kit, that runs straight to the battery or altrenator or something that plugs into the factory fuel pump harness, that give you more power to the pump, or stabilizesfuel pressure, or voltage or something.
to be honest im not sure what it does, just that everyone recomends it. not just installing the pump.
Old 12-09-2008, 02:42 PM
b4c346's Avatar
jeg's sells them.there made by casper electronics.like $85.00
Old 12-09-2008, 03:21 PM
ouch i thought i had read someone talking around $35
Old 12-09-2008, 03:51 PM
Racetronix also sells one, in 3 levels from basic to deluxe. It ranges from 60 to 80.
Its function is to supply steady current (and thus voltage) to the pump even under extreme conditions such as WOT. It has heavier gauge wires, a relay at the back to boost voltage, and excellent connectors throughout. I would personally not install a more powerful pump without it.
Here is the link for a 99 and up:
http://www.racetronix.com/RX-F99-FPKG-2.html
The quality on the components is first class, I have the deluxe one on my car.
Old 12-09-2008, 05:08 PM
ItsNotStock's Avatar
I would also go with the Racetronix kit as the higher tiered kit has provisions for a BAP. And looking at your mods this might be very helpful when your boost kicks in.
Old 12-10-2008, 09:26 AM
Bap? ..
Old 12-10-2008, 10:24 AM
Nasty N8's Avatar
I keep them in stock for alot less that $85
Nate
Old 12-10-2008, 11:08 AM
how much i cant find them on the site. info/link/price?
Old 12-10-2008, 12:44 PM
Nasty N8's Avatar
They are $59.99
Nate
Old 12-10-2008, 01:25 PM
02blueLS1's Avatar
i bought mine from Full Throttle Speed on ebay for $39 and $10 shipping so total $50.
Old 12-10-2008, 02:55 PM
found it. $39.99 + $9 = $48.99
same 10g wire, and has the extra grounds that racetronix charges you $12 for.
many thanks!
Old 12-13-2008, 12:12 AM
LS1TECH Sponsor
Racetronix's Avatar
The FT harness is not quite the same in a few areas of construction and material. FTR's harness layout is based on our original release of our harness from many years ago. Since then we have made some upgrades and changes.
  1. Some wire gauges are different
  2. We use Nylon loom vs. PVC. Nylon is more expensive b/c it has the highest temperature rating and resistance to solvents. PVC is much less resistant to solvents (gas) and usually deforms/melts in hot engine compartments.
  3. We heat-shrink our harness ends. FTR tapes theirs.
  4. The FTR harness does not include/offer a battery to body ground upgrade.
  5. We provide a lifetime warranty. FTR offers one year.
  6. We manufacture our own harnesses. FTR's harnesses are outsourced.
Our BGC is comprised of an 8 gauge wire with spiked terminals which hooks between the negative battery terminal and the body ground. Our kit comes with two battery nuts not one. We supply 25 wire ties, dielectric grease, spare fuse, SS screws, etc.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 12-21-2008, 12:10 PM
02' hawk's Avatar
Originally Posted by STANG KILLA SS 2
Bap? ..
Boost-A-Pump. I have one and works GREAT i got from MSD
