Quickets Stock Motor + Single power adder list
Old 12-10-2008, 02:31 PM
Ruckus46Gt's Avatar
Default Quickets Stock Motor + Single power adder list
Lets start it:
The 50 Quickest Stock Motor + Single power adder
ETs must be out to three decimal places, (i.e. 11.XXX) and include all the information required for the list.
..: Single Power adder- Bolt-on's - Stock Motor* - That means no head/head work, no cams
Board ID - 1/4 ET @ MPH (60ft), Yr & Type of car, Converter/Clutch, Gear, Boost/How big of shot, Race Weight, Date
UL LOSE-10.890@123.669 (1.470),02 WS6,Vig3200,4.10s,TNT 150,3550lbs,2/25/2006
MeanYellowZ 10.903 132 mph, 1962 Chevy II, 3500 stall, TH400, 3.55 open rear -235 tires, 5.3 - Single S400 turbo, 3140lbs 8/29/08
Ruckus46gt - 11.048@123.081 (1.547), 1999 Camaro SS, 3k stall, 3.23, 100(w/nano), 3600,12/06/08
01_Ram-Air - 11.07 @ 121 (1.56), 01 Trans Am, 4k Yank, 3.42, 150 NX, 3500+ 05/2007
LSxPwrdZ - 11.084 @ 123.4mph (1.574 60ft.), 2000 Z/28, Textralia OZ700 Z-grip, 3.89, 150shot, 3650lbs, 11/2007
polarischevy05-11.360 @ 117.97 150 shot tci 3500 stock rear end 2.73 26x11.5 et streets full wieght car
Old 12-10-2008, 02:35 PM
Ruckus46Gt's Avatar
*Not going to update until we get at least 10 car or so
Old 12-10-2008, 03:10 PM
Dragkid1917's Avatar
Why can you have an exaust but not an intake? it should either be totally stock motor or full boltons only. JMO.
Old 12-10-2008, 05:32 PM
Ruckus46Gt's Avatar
does the stock internals list allow intake? I didnt think they did could be wrong though
Old 12-10-2008, 07:38 PM
LS1Z28-00's Avatar
yes they allow an intake. everything but heads/cam pretty much.
Old 12-10-2008, 08:12 PM
Ruckus46Gt's Avatar
sounds good thats what we will do the list as..updated top
Old 12-11-2008, 01:15 PM
bad6as's Avatar
so this is a stock internal list, but it can have a turbo, turbos, supercharger or n20
Old 12-11-2008, 02:12 PM
Ruckus46Gt's Avatar
correct...list to see how far people can/have taken the car before opening up the long block. Also curious to see if a nitrous car has it or if its a mild boosted turbo or supercharged car on top.
Old 12-11-2008, 02:27 PM
jason02Z's Avatar
bolt on boost 10.85 @ 125.86
Old 12-11-2008, 03:01 PM
quickblade's Avatar
stock internals.. stock everything except SLP air lid....
oh and gears... 3.73.. other then that I have done nothing...
well added 150 shot...
So on my car.. best has been
11.899 spraying the 150 shot on street tires.... Spinning to hell all the way thru 1st gear.
MPH: 118
60ft 1.999..... so pretty much 2.0 60ft.....
No stall... no suspension.. still stock suspension...
Old 12-11-2008, 03:14 PM
streetassasin's Avatar
well I know I wont even be close but here it goes:
streetassasin, 12.392 116.96 mph, 2001 Camaro SS, stock converter, 3.23 gears, 100 shot 10/10/2008
Old 12-11-2008, 03:28 PM
egucci's Avatar
my 200o camaro went a 10.63 at 131
lid, cut out, converter 3.73 gears and a 150 shot on mt et streets
Old 12-11-2008, 04:42 PM
clemsondave's Avatar
Fastest completely stock longblock C5
clemsondave - 10.19 @ 135.9 (1.44), '03 Z06, stock 6 speed M12 trans, McLeod RXT, stock 3.42, P1SC, race weight - 3310, 11/08
'03 Z06
P1SC
6 speed
Stock trans
Stock gears/diff (hardened output shafts)
595/495
*Tuned by Frost at LSxTune*
Old 12-11-2008, 06:33 PM
blakern's Avatar
I hope to make the list this spring with my 100shot/nano combo.
Old 12-12-2008, 01:37 AM
MeanYellowZ's Avatar
Old 12-12-2008, 05:04 AM
Ruckus46Gt's Avatar
please follow format...will update when there are a decent number of entries
Old 12-12-2008, 09:46 AM
jason02Z's Avatar
jason02z-10.85 125.86mph 1.63 60'-2002 z28 tci3500 stall mild built stock 4l60 stock 10bolt 3520lb. 10/10/08
Old 12-12-2008, 01:08 PM
Kingc8r's Avatar
Good idea...hopefully I can contribute in the next coming months
Old 01-06-2009, 02:29 PM
polarischevy05's Avatar
Old 01-06-2009, 10:14 PM
01_ram-air's Avatar
05/2007
Quick Reply: Quickets Stock Motor + Single power adder list
