My dyno #s
Old 12-15-2008, 07:51 PM
juanito's Avatar
Default My dyno #s
OK. dynoed the car on sun. made 256rwhp and 273tq
mods in sig. why did i hit so low? i read some stock cars doing atleast 15hp more than this. its ran lean though (at 15.22).
Old 12-15-2008, 08:10 PM
SnakeOiler's Avatar
LS1Tech 20 Year Member
Originally Posted by juanito
...its ran lean though (at 15.22).
that would be the problem
Old 12-15-2008, 08:19 PM
blake110106's Avatar
that is way lean. is it staying lean through all the RPM's or up high?
I wouldnt go WOT much. Get it tuned and you will see jump in both.
Old 12-15-2008, 09:04 PM
crazyhorses's Avatar
What kind of dyno was it? I actually heard that stock cars do lower whp than what you put out, but what you put out is lower than others with similar mods so I hear your concern.
It is lean, getting it tuned will help out. I gained about 15+whp throughout the rev range from a tune alone. I hope that MAF won't get in the way.
Old 12-15-2008, 09:18 PM
stephen p's Avatar
also depends on what kind of dyno. if it's a dyno-jet, those are pretty crappy. numbers..but if it's a mustang or dyno dynamics. that's about right. because those two dynos are "load bearing" which means they have resistance on the rollers and simulate road conditions. they are more for tuning than good numbers.
Old 12-15-2008, 09:41 PM
Formula350's Avatar
We discussed resistance in another thread, and I still don't understand how adding resistance = truer numbers since driving conditions and being on a dyno are the same. Still earth's gravity affecting the weight on the car. I still think a DynoJet will put some resistance down to account for the change in pushing the other bit of the car.
Either way, on topic... The fact you have an A4 and the fact it's running way lean doesn't help any. The only real power adder is the CAI and exhaust as that MAF doesn't help any. I think I remember it hurting some people's performance and might be the reason for lean condition. The trans being built will actually help some, but not all that much.
Old 12-15-2008, 10:06 PM
fergymoto's Avatar
I would clean the MAF or get rid of it and put a stock one back on. Then see how your AFR looks.
Old 12-15-2008, 10:13 PM
Elliott's94Z's Avatar
Have you had it tuned? If you are running lean you are missing out on HP. My advice is to have the car "dyno tuned" and you should hopefully see some better numbers after. Don't feel to bad, when I had my first dyno my car was running extremely lean up top and I dyno'd 260 at the rear. Got that fixed up real quick
Old 12-15-2008, 10:33 PM
BlackLT1Z's Avatar
It's running lean, no tune, and you have a stall that probably isn't very efficient.
Old 12-15-2008, 10:39 PM
Moderator
BizZzatch350's Avatar
Mine made 260HP and ran 12.80s, that was with long tubes and a 3200 stall. Go see what it runs.
Old 12-15-2008, 10:40 PM
slomarao's Avatar
+1 on that.
Old 12-15-2008, 11:06 PM
fergymoto's Avatar
You guys keep saying he needs a tune. The thing is stock! It should be rich if anything. Like I said before, look into the MAF. You have a problem somewhere and that is probably it.
Old 12-15-2008, 11:11 PM
I missed the stall part..+2
Old 12-15-2008, 11:51 PM
Puck's Avatar
Bad A/F, nearly stock auto car, and a stall...numbers seem close to me!!!
Your trap mph on a track will tell you more about how your combo is running then dyno numbers, especially being an auto.
Old 12-16-2008, 12:11 AM
juanito's Avatar
sorry. it was a dynojet . and i threw that maf in there minutes before the runs because i though my stocker was bad (man do i regret it) . car has a madZ28 mail order tune. and it ran lean througout the whole run.
Old 12-16-2008, 12:12 AM
Marc3.4V6's Avatar
where should our A/F ratios be? I'm 11.2 @WOT. Is that good?
As for the OP.... Maybe the tuner leaned it out too much?
Old 12-16-2008, 12:18 AM
It's not stock..read his sig or his orig post. I still think you need to have a dyno tune. My mail order from a certain company I won't name ran my car extremely lean on the dyno. Put my orig back in (didn't supply my box) and it ran perfect w/ no lean spike.
Old 12-16-2008, 12:22 AM
fergymoto's Avatar
It has exhaust, intake, and a stall. That's pretty stock
Old 12-16-2008, 01:26 AM
LT's....not the point either way it could run lean with or w/o them or require a tune
Old 12-16-2008, 01:29 AM
fergymoto's Avatar
Last time I checked headers were part of the exhaust system lol
Quick Reply: My dyno #s
