ls3 heads need vave springs
Im looking for valve springs that will support .670 lift also what are the best lifters to use for this lift also. I found comp has part number 26926 but they are not released yet any others?
Take a look at the chart below, all data is based on manufacturer specifications. The valve springs that support .670 lift based on spring coil bind specification and calculation with .060 safety margin are circled. Sorry for the size, it's a lot of data. I included the PAC-1521 because it's within .010" of the others and could be used.
Assumptions: 1.800" installed height, .060" clearance before coil bind, load to support an aggressive lobe.
405HP_Z06 thanks for great data!
