can i hide this n2o?
i want to run a 150 shot or so, what do i need to do to hide this from people that look under the hood? is there a system out there that will get this done? thanx
also, is it even safe to run a 150 shot on a stock system?
Re: can i hide this n2o?
You could try the spider kit. It's either NOS or NX that makes it. It is a direct port injection that goes under the intake so no one will see any hint of the nitrous.
Ryan
Ryan
Its a nos cheater kit if i remember right, but it wont fit betwene the intake and the valley cover. I asked this a while back. It might be doable with the new fast intake since its a 3 part design, but you would have to get your hands on one to tell if you could route it on the inside.
The kit that goes under the intake will only fit with an LS6 valley cover. A friend of mine had it on his 02 Z so I know it will work.
I wouldnt spray anymore than a 150 shot on the stock fuel system.
Ryan
Ryan
do you think that this page is a good idea to go by?
http://joshker99.home.comcast.net/installpage.htm
so.. if i do this,
the most i can run is 100?
i was thinking i should try to run 150
