What do you need/want to fix?
Driver side mirror dosnt move.
Figure out the cruise controll.
Fix the lumbar/bolsters.
5 Spoke wheels.
The list has gotten alot smaller recently. But Alot of the work is simple fix.
5 Spoke wheels.
I've already fixed a lot that I wanted to. But much still remains.
Figure out what's scratching the inside of my windows
Dye the ebony console top to match my graphite and replace my busted unit
Get a Hurst or Pro 5.0
Clearcoat my tails (already tinted, but looking a little rough)
Repair and repaint my pass 1/4 panel
Install the 4 new tires I have sitting around
Install pillar gauges
Install soon to arrive gauge overlay
Damn, list is bigger than I thought!
I need:
motor mounts
dash pad recently cracked
front nose painted
I want:
engine rebuilt
wider tires - I'm on 245's :o(
new set of floor mats
All in all everything else it good. I've spent the past two years putting it back together and slightly modifying it. When I got it there were many little problems but it was still worth the $8k I paid.
motor mounts
front nose painted
I want:
engine rebuilt
Fix the headlight issue (we have it narrowed to an automatic popup fault)
Get my rear driver side rim fixed so it stops leaking air
Find out why my passenger side tire is going into the wheel well but the driver side isn't
New lid since the whisper isn't fitting right anymore
Kooks LT headers to get rid of the pacesetters since Texas Speed sent me the wrong ones long ago
Fix spiderwebbing that happened on the front when someone hit my front end
Change the foglamps since the passenger side is burnt out
Cracked door panels on both sides... in the infamous spot
Find matching ebony paint to paint my door bezel (nobody wants to help me with this and help find the paint color )
*sigh*
Fix 1 thing only to find 2 other things need work
*sigh*
