2-step
2-step
hey fellas..im quite sure i remember me by now, i have the 98 camaro z28 m6 with the troubled sts set up...im looking for a two step so i can actually launch the car..im gonna be ordering my rear end pretty soon as well as a few other things cuz i have a lil event im going to in mid january, and i would like a 2-step so i can leave under boost and get a good time...any one know of one for a good price? new or used...if some one on here has one for sale that would be cool too...thanx guys....
Swirlly
Swirlly
do you have any videos of this car..i would love to hear it ...what rpm do you guys have it set at?
Maybe a little off topic, but... I tried mine out today (the 2-step is built in on the big stuff 3). I must say it is pretty cool!
I have it set at 2800 rpm, it takes about 2 seconds and it was building boost. I released the brakes at 3 psi and did a nice rolling 200 foot burnout. That will be a fun feature when I start playing with it, the timing and rpm need to be optimized to realize the full advantage of the 2-step.
Mine is at 3k and I built about 4psi. I haven't tried retarding the timing with it yet. Zombie posted that he had good success with pulling 5* for a m6.
I will get a video, it is insanely loud when it goes to popping. I have already sent 2 crowds running at the local meets.
I have Lpe. Set @ 4300 rpms, pulling 8 * of timing, makes about 5 psi out of the hole. this is on a 6 spd car. It works greta by the way.
Heres 1 vid.
http://www.youtube.com/watch?v=UQDZSiYL8VU
Chris
Heres 1 vid.
Chris
Same race from the other side.
http://www.fquick.com/videos/Mwir_Dr...ng_2_step/7151
And 1 more.
http://www.fquick.com/videos/2_step_burnout/7154
And 1 more.
The Trans is a stock t56 with a Centerforce DFX clutch.
Im dropping the clutch, I think it slips a little, but that clutch was in the car for bolt ons, and not for the power im making. It holds fine except on launches. I really dont care about it cause im gonna go to a th400 with a brake.
Anyways, with the 2 step where it is, its pretty consisten low 1.7's. In a full weight turbo 6 spd car i dont think its to bad. If i throw a couple more hundred rpm @ it it will be int he 1.6's for sure, but im trying not to break the trans.
Lastly i think the car is undergeared for the power im making. Right now its a 3.50 gear in the fab 9. Im still only @ 6 psi, and a little shy of 500 whp, but that should hopefully be better next yr.
Chris
Lingenfelters LNC-002 is awesome. For the auto guys who want one MORE step/rev limiter....the lnc-003 is even better. You can then do like the big dogs.....go on the first step on the foot brake into the prestage beam and then go to the 2nd stage on the brake in the stage beam.
i just got the first one...lnc-003
I got the first step wired into the ebrake light switch under the ebrake handle.
the 2nd step is wired with the tbrake
i get 2 psi at 2600 rpms before i ever get to the prestage beam and then once i stage and go on the 2nd step i get 5 psi instantly. This is awesome for auto/turbo guys.
I have mine hooked up to the brake light switch. So I just brake torque it and it is on the 2-step. Works good for now until I get the trans-brake. I have a line lock for the burnouts.
