low 11's A4 cam only
hi guys ..
my old number 12.06 118MPH 1.74 60' with cam only + 3500TC + 3.23
it's possible to hit 11.5X or lower with my new mods??
this the new mod
3.73 (stock 10bolt)
adj Qa1 R + 275lb springs on the Front
Comp engineering stock springs on the rear
UMI LCA's - UMI LCA's brackets - UMI adj PanhardBar -UMI subframe
SDtune
weld prostar with MT DR's 275/60/15
! rear seat
this the new mod
3.73 (stock 10bolt)
SDtune
! rear seat
well you should have 26inch tires on the car IMO. you want to be more in your power range to make the best times and with 28s in 3rd headed toward the stripe it is nowhere close to that im sure. you want to be right at or just past peak power going through the finish. that is what you aim for in gear and tire size selection
