clear corners
Re: clear corners
Arg, I just got my clear corners for my camaro in the mail, and I can't get them out from the bottom. I got the screws out, but just can't seem to shimmy it out. Do I have to take the whole headlight bracket out?
Re: clear corners
I'm back, https://ls1tech.com/threads/showflat...rue#Post515435
B-MAN, sorry about getting your post off subject, how about a pic of your car with the new clear corners?
Re: clear corners
its really simple. Just take out the 5 push pins across the center of the nose between the headlights. then take out the 10mm bolt holding the headlight in. and pull the nose up over the lip there. Then slide the headlight to the center and angle it out.....then all you have to do is play with the lenses to get them at the right angle for them to come out. It's actually really easy. Laterz Justin
Re: clear corners
cool, I'll try and get a picture up within the next couple of days. let me know what you all think. I try to keep my car tasteful and not tacky
