Max lift for yellow LS6 valvesprings?
Old 12-27-2008, 08:59 PM
kst8engineer's Avatar
Default Max lift for yellow LS6 valvesprings?
I've been searching, but I haven't been able to find an answer. What is the maximum lift that yellow LS6 valvesprings can accomodate safely? I'm getting ready for a cam swap, and the cams I'm considering are in the .547 - 0.581 range.
I think the 02+ LS6 cam had lift specs of .551/.547, so it sounds like the yellow springs should handle 0.547 safely.
What about the 0.581 lift cams -- would the yellow springs be a reasonable choice here, or would I be pushing them too far? Would I need to step up to some Comp 918's?
Thanks
Old 12-27-2008, 09:16 PM
hokie00 TA's Avatar
.570 max lift. im running a tr224/224 .563/.563-112 and havent had any trouble yet gonna change them out soon for some patriot duals.
Old 12-27-2008, 09:27 PM
CalSpeedPerformance's Avatar
I believe .570 is about right from checking coil bind and spring pressures.
Old 12-27-2008, 10:23 PM
Thanks for the quick replies!
Old 12-27-2008, 10:37 PM
NemeSS's Avatar
i wont run anything with more than .550, but thats just me.
Old 12-28-2008, 12:18 AM
405HP_Z06's Avatar
Do you know the CB on these springs?
Old 12-28-2008, 01:36 AM
blackLS1m6's Avatar
I think coil bind is 1.085" on the LS6 springs.
Old 12-28-2008, 09:48 AM
01ssreda4's Avatar
no ****. the piston smacks the valve if one of these babies break so go with PAC 1218s instead.
Old 12-28-2008, 12:25 PM
Ive never seen/heard of a broken ls6 valvespring..so thats my last worry
Old 12-28-2008, 05:38 PM
djsanchez2's Avatar
Yellow Z06 are .550
Blue stripe Z06 are .580
Old 12-28-2008, 06:22 PM
01ssreda4's Avatar
pushing it so close to the limit is asking for trouble.
Old 12-28-2008, 06:49 PM
regblkss's Avatar
I ran the yellow spring's on my 224tr for a year or so untill I got my heads.
Old 12-28-2008, 09:51 PM
blownerator
BlownChevy's Avatar
Seen sever break myself.....You have just been lucky.
Quick Reply: Max lift for yellow LS6 valvesprings?
