Intermittent code 43
Old 12-30-2008, 02:10 PM
camar0corey's Avatar
Default Intermittent code 43
Alright so in the tune knock sensitivity was set low, also have a LT4 KM. Yet I get a code 43 that pops up and goes away as I'm driving. What can I do about this? Its not knocking so far as I know, SES light didn't pop up during the dynotune either. Like I said it shows up then goes away for a few minutes, then comes back, sometimes doesn't show up at all. New AC Delco knock sensor also. I'm perplexed. What can cause it to trip?
Old 12-30-2008, 02:51 PM
black_sunshine's Avatar
maybe this will help
http://www.fastbird93.com/diagnostics/dtc43.jpg
Old 01-01-2009, 09:20 AM
Thanks for that, but it seems I need the facing page according to that, as my code is intermittent. Its driving me nuts, some trips it never comes on, other times it pops on and off multiple times.
Old 01-02-2009, 09:21 AM
Any more advice out there on this?
Old 01-02-2009, 01:13 PM
blackz93's Avatar
Bad connection. Mine does it, too, and sometimes I have to get under there and re-arrange how I have it plugged in.
Old 01-02-2009, 01:25 PM
fergymoto's Avatar
Might want to try a new pigtail. Cheap and easy cause to eliminate
Old 01-02-2009, 02:27 PM
9-Second Club
Ed Wright's Avatar
Yep, it is often the connector. Heat is hard on it. A pigtail often fixes that.
Old 01-02-2009, 03:33 PM
borninatransam's Avatar
I'm having the same troubles with my 383 right now. Tried a new sensor, module, rewired it and still no luck. We've tried getting the sensitivity down through tuning and still no luck. The worst part is when it happens im pulling 7 degrees of timing at idle and anywhere between 10-12 at WOT. I've checked plugs and they're fine so I'm at a loss. Any other ideas would be great.
Old 01-03-2009, 08:51 AM
Thanks guys, I'll try a new connector. Stuff freaks me out some trips it doesn't even pop at all. I suppose after 14-15 years the connector probably isn't that healthy being exposed to the heat as stated and sorta being in the open down there.
Old 01-09-2009, 09:40 AM
New pigtail, problem fixed. Thanks!
Old 01-09-2009, 03:00 PM
Good to know. Ordering one now.
