VATS bypass help me!
Old 12-30-2008, 07:30 PM
robster's Avatar
Default VATS bypass help me!
ok, i have no clue as to what to buy and the people at radio shack are tards. i printed out the chart off of shbox and it looks like numbers to me. tested my keys and it is 9.53K. what resistor do i need?
Old 12-30-2008, 09:03 PM
poconojoe's Avatar
Get a pack of 271-1330 these are 4.7K resistors. Put 2 of them is series and put that across your wires. This will give you 9.4K of resistance, which is close enough.
Last edited by poconojoe; 01-01-2009 at 12:35 PM. Reason: For some reason I misssed the zero on the end of the part number
Old 12-31-2008, 12:01 PM
robster's Avatar
ok tried that. light just stays on now and no start. maybe they arent in good?
Old 12-31-2008, 12:16 PM
poconojoe's Avatar
Are you sure you read your key correctly?
Old 12-31-2008, 12:44 PM
robster's Avatar
pretty sure. both keys read 9.53k
Old 12-31-2008, 04:33 PM
2001NBMZ28's Avatar
That should work assuming they're at least 5% resistors. What's the resistance of them in series before putting them into the connector?
Old 12-31-2008, 06:19 PM
poconojoe's Avatar
On the older setups using the VATS module, before they incorporated it the BCM, I've never had an issue, as long as it was within 10%
Buy 2 packs of the resistors(they're cheap enough) and measure all of them and pick the 2 that add up closest to the correct value.
Old 01-01-2009, 01:22 AM
robster's Avatar
ok. the keys read 9.53K. i bought 4.7K resistors and used 2. nothing happend. wrong ones?
Old 01-01-2009, 09:04 AM
poconojoe's Avatar
Did you put 2 of them in series not in parellel?
what was the total resistence?
Old 01-01-2009, 10:18 AM
Doc
Doc's Avatar
How did you hook it up? IMHO, taking the under the glove box panel off and going to the bcm connector, White with black stripe wire pin 7 with your resistors straight to ground is the most straight fwd method.
That is, for an Fbody.
Is this F or Y?
Old 01-01-2009, 12:03 PM
poconojoe's Avatar
Is this F or Y?
But he has to make sure he disconnects the wire going over to the key of the key will be in parellel and cutting the resistance in half
Old 01-01-2009, 12:18 PM
robster's Avatar
02 camaro. all i did was unplug the vats under the drivers side (white wires wrapped in orange) and shoved the 2 resistors in the plug from the harness
Old 01-01-2009, 12:34 PM
robster's Avatar
ok, heres what i just did. i took and unplugged the connector, put the key in and checked the wires from the key cylinder with the multimeter. i believe i should have gotten the same reading as the key, but i got nothing. does this confirm a broken wire in the column area?
Old 01-01-2009, 12:59 PM
poconojoe's Avatar
What color are the wires on the plug you're checking?
Old 01-01-2009, 01:00 PM
poconojoe's Avatar
Are you sure that isn't for the SIS?
Old 01-01-2009, 01:31 PM
robster's Avatar
purple w/white stripe and white w/black stripe
Old 01-01-2009, 01:55 PM
robster's Avatar
i fixed it. thanks guys
