heads
Old 12-31-2008, 01:33 AM
chaser2racing's Avatar
Default heads
im new to lt1 scene but have been playing with my 69 rs ss since i was 15 just bought 94 firehawk it needs a little more than 315 the plaque says looking to at least break 400rwhp should i buy heads or get them ported going to be putting headers and electric water pump on soon already have under drive pulley and airfoil skip shift has been eliminated tell me what to do to get the most bang for my buck
Old 12-31-2008, 05:47 AM
96LT1355Z28's Avatar
Look up Advanced Inductions or Lloyd Elliott Portworks. Then MadZ28 or PCMforless and get a tune. Their combos will steer you in the direction you want to go. Once you get a tune you can sell your skip shift eliminator. Also look into suspension items they will make a difference. My best advice is have a goal for the car, 400 rwhp is doable with the above mentioned people. Figure out what you want to do with your new HP, street car, street/strip, road race, all out drag. That will help you decide where you'll want your power (rpm wise) and help with suspension decisions. Good Luck!
Old 12-31-2008, 09:22 AM
Elliott's94Z's Avatar
Send your stock heads to Lloyd and have him port them. He can custom grind you a camshaft that best suites your needs as well. With LE2 heads, LE2 cam and the supporting mods you should be well on your way to that 400rwh mark!
Elliott
Old 12-31-2008, 12:35 PM
ZeeTwentyFate's Avatar
AI all the way, they are a sponsor here tehy have proven results right on their page
http://www.advancedinduction.com/
Old 12-31-2008, 01:41 PM
AChotrod's Avatar
LE all the way I am one of his proven customers making 413+ Rwhp with a heavy Dana
S60 rearend in the car. With a 10bolt those numbers would be more like 425-430rwhp. on a stock short block! It dont get much better than that!!!! Unless you go cam crazy!!!!
Lloyd Elliott rocks!!!
Old 12-31-2008, 07:59 PM
thanks guys for the direction
Old 12-31-2008, 08:51 PM
speed_demon24's Avatar
See sig. They also have proven track results unlike a lot of the competitors.
Quick Reply: heads
