Finally did the LS1 lid conversion
Old 12-31-2008, 10:00 AM
tspence45's Avatar
Default Finally did the LS1 lid conversion
Well, I decided that I wanted to do atleast one of my mods that I had laying around, before I go to the track tomorrow. So, I finally bit the bullet, and decided on the LS1 lid conversion. I used an MTI carbon fiber lid, with a K&N filter. Here's a couple quick pics I took yesterday morning of it. I'm not 100% done with it though. I want to make a radiator cover for it, to help keep some of the engine bay heat away from the filter. Also, I know the engine bay's dirty, but I'm going to do a lot of work cleaning it up after this week, and have it good and clean for Spring.
Here's a picture of where you have to cut, so the stock hook will clear the lid. I still need to smooth out the edges of the cuts though.
I'll try and get some more pics up later this afternoon or tonight.
Old 12-31-2008, 10:08 AM
BlackLT1Z's Avatar
Ummmm what is holding the lid down firmly onto the filter so that no dirt gets past it?
Old 12-31-2008, 10:14 AM
robsquikz28's Avatar
nice job just so peesp know where and what did you use for the rubber hoses to the throttle body and m.a.f
Old 12-31-2008, 10:18 AM
connexion2005's Avatar
Can we get a few more pics man? I cant see where you cut, what is supporting the radiator, and what is being used as the lower air box for the lid. Looks great though!
Old 12-31-2008, 10:23 AM
Elliott's94Z's Avatar
So is there any real gain with this set up?
Old 12-31-2008, 11:09 AM
96lt1m6's Avatar
my gain was 2 tenths over the crappy moroso done at the track. that was also with a fram paper filter along with the stock Ls1 bellows.....
by far one of the fastest,benificial mod and cost wise,it cost me 50.00 and 15 min.
Old 12-31-2008, 11:36 AM
hartman's Avatar
time at the drag strip isnt really a good way to measure gains because you could of just had a better run. Dyno proof would be better because i dont think there is 2 tenths gain with that lid over a CAI.
Old 12-31-2008, 11:50 AM
djjab57's Avatar
Hmmm can we clean up that bay a little bit please !!! LOL
Old 12-31-2008, 12:05 PM
Exactly...to much comes into play at the track. I wanna see some dyno numbers with the different set ups. Anyone?
Old 12-31-2008, 12:12 PM
2XR95Z28's Avatar
You get those 1.7's on there yet? what time you going to the track tomorrow? might stop out...
Old 12-31-2008, 12:31 PM
96lt1m6's Avatar
well i will tell ya this,if your car ran consistant #'s and you changed something and now your car runs differently you would then suspect the mod you did is what caused it,correct?
i could give two ***** about what a dyno says,dynos do not give time slips!
infact there are a few people that have had the same results look up "the merv"......
Old 12-31-2008, 12:35 PM
Black94Z28's Avatar
Looking to do this to mine too...what is holding the lid down? I had mine mocked up and was trying to figure it out
Old 12-31-2008, 12:46 PM
I think what he's getting at is there's a lot that comes into play at the track. Not doubting you noticed a change but in the end the BIG question is, does going with this style of CAI give gains that are worth while to do the swap?
Old 12-31-2008, 12:48 PM
BlackLT1Z's Avatar
I've seen the radiator supports for LS1 cars go cheap. You might be able to swap to one of those.
Old 12-31-2008, 01:01 PM
the_merv's Avatar
^^That won't fit..
With it I picked up about .2 easily, and 2 mph. It just flows better.
Here is pics of mine, I used Stainless Steel to hold it down and to keep the Radiator forward. I cut into the Core Support also.
A little before and after for you guys so you can see how it is setup..
Old 12-31-2008, 01:07 PM
vanilla89's Avatar
I'm about to do this swap on mine, I plan on doing a back to back test, same day at the track with the ls1 lid and a moroso cold air kit.I will have a ws6 filter holder and a fast toys lid.Try to pick up a tenth or so and get the heavy *** car in the 6's.
Old 12-31-2008, 01:28 PM
96lt1m6's Avatar
For the amount of posts and threads on this topic it really makes me wonder how anyone can attempt to disprove the gains!
i guess the calculated version of the ws6 ram air was just a reason an engineer at GM came up with to justify his/her job!
Old 12-31-2008, 01:33 PM
SS MPSTR's Avatar
The gains, IMHO, could easily be 2 tenths. In fact, I'm going to do that mod next, but need to find someone who has done it cleanly. No offense to anyone's ride here, but I want a factory look while retaining my SS hood.
Old 12-31-2008, 01:36 PM
fuel's Avatar
i like the ls1 lid set up
Old 12-31-2008, 01:49 PM
AChotrod's Avatar
I have no doubt in my mind that mod or a LT1 WS6 intake is better than a CAI. Way to much plumbing on a CAI and the filter is in a poor spot. IMO
Quick Reply: Finally did the LS1 lid conversion
