real quick question on deleting ac
Old 01-02-2009, 09:00 PM
shutzero's Avatar
Default real quick question on deleting ac
do you take out that radiator looking thing in front of the actual radiator when deleting the ac?
Old 01-02-2009, 09:06 PM
Stroked96Bowtie's Avatar
Yep thats the condensor. Does no good without the rest of it.
Old 01-02-2009, 09:33 PM
RamAir95TA's Avatar
Leaving it in won't hurt, but for complete removal it's gotta come out.
Old 01-02-2009, 09:42 PM
shutzero's Avatar
What about the plastic piece over it?
Old 01-02-2009, 09:46 PM
RamAir95TA's Avatar
If you're talking about the radiator support (big black plastic piece you see when you open the hood with the labels and such), yes you need it!
Old 01-02-2009, 09:49 PM
sprayed5oh's Avatar
Yup you need the plastic peice,it holds the top of the radiator.
Old 01-02-2009, 09:53 PM
shutzero's Avatar
The one going over the top of the condensor?
Old 01-02-2009, 09:55 PM
RamAir95TA's Avatar
See above.
Old 01-02-2009, 10:06 PM
sweetbmxrider's Avatar
the one in front of the condensor towards the nose of the car should be replaced after you remove the condensor. it helps direct air flow over the radiator to keep the car cool
the_merv's Avatar
Yea, leave the black plastic piece. You will have to take it off to remove the Condensor, but put it back inplace.
Old 01-02-2009, 10:17 PM
shutzero's Avatar
Its not the shroud with the labels on it...
Old 01-02-2009, 10:24 PM
RamAir95TA's Avatar
Perhaps a picture would help with what you're talking about....
Old 01-02-2009, 10:38 PM
i know what you are describing, replace it after you remove the condenser. like i said, it helps direct airflow over the radiator.
Old 01-03-2009, 01:50 PM
robsquikz28's Avatar
yes keep it in its the lower splash shield but the time directs air to the radiator leave it in
