'97 LT1 Gauge Cluter Swap into '95 LT1 Seatbelt light problem
Old 01-04-2009, 08:10 AM
marc1130's Avatar
Default '97 LT1 Gauge Cluter Swap into '95 LT1 Seatbelt light problem
Okay so heres the deal, I swaped a newer '97 digital odometer style gauge cluster into my '95 trans am.
The seatbelt light will not go off. It starts out bright when the seatbelt is unlatched and then it dims when the seatbelt is latched.
I've tested the convenience center and do get the appropriate 5-8 second chime when turning the ignition to run without the seat belt latched and the LH door shut.
I have also tested the seatbelt switch by unplugging the harness. The indicator lamp goes from bright to dim.
I know that the newer gage cluster uses a LED instead of a bulb. I also know that the newer gage cluster is used in cars with the body control module, my car does not have this because it is OBDI. I wonder if one of those two factors is causing the problem because the indicator lamp works fine with my old cluster.
I would lso like to add that I have tested a different '97 v6 gage cluster to eliminate the possibility of a faulty gage cluster.
There must be some kind of short cause a lower voltage signal to pass through the indicator bulb circuit making the light stay on.
Old 01-04-2009, 09:29 AM
marc1130's Avatar
I went through the diagnostics in the manual, removed the audio alarm control module from the convenience center under the driver's side dash and then checked the terminals from the seat belt switch behind the driver's seat. With the module removed, I'm getting 12 volts on the black/white wire (seat belt indicator signal circuit 238). According to the flow chart I have a short to ground in the black/white wire. This wire also connects to the Diagnostic Energy Reserve Module behind the glove box.
Looks like I'd have to tear apart the passenger side dash, center console, driver's seat and the carpet on the driver's side to inspect this black and white wire for a short to ground.
Old 01-08-2009, 07:57 PM
jedimaster71472's Avatar
Really dude? Just for a light? Ignore that ****.
Old 01-08-2009, 08:56 PM
marc1130's Avatar
moderator: please delete post 3
Old 01-11-2009, 07:30 PM
Might as well delete posts 4 and 5 as well.
Old 01-11-2009, 10:50 PM
darrell hoagland's Avatar
my buddys is the same way it is on and wont go off
Old 01-11-2009, 11:18 PM
marc1130's Avatar
The only difference is a diode instead of a bulb, someone please help me figure this out, and the Body Control
Module VS the Audio Alarm Alert Module. What year is your buddy's 'bird?
Old 01-11-2009, 11:37 PM
95 trans am
Old 01-12-2009, 12:25 AM
marc1130's Avatar
okay so the problem only occurs on '93-'95 trans ams/firebirds because they first implemented the BCS in '96 being that is what controls this feature
Quick Reply: '97 LT1 Gauge Cluter Swap into '95 LT1 Seatbelt light problem
