Sponsor Group Purchases - LME SHORTBLOCK SALE w/ FREE SHIPPING
Bryan@LME
01-07-2009, 10:28 AM
LME is offering great savings on our most popular combinations.
Along with these great prices LME will cover freight costs to the lower 48 states!
All shortblocks are fully balanced, blueprinted and assembled.**
LS7 430 or 440 CID.
-GM LS7 aluminum block w/ steel main caps
-Callies Compstar 4340 4.0” stroke crankshaft (4.100” stroke for 440”)
-Callies 6.125” H beam rods w/ ARP 2000 7/16” bolts
-Wiseco custom forged 4.135” pistons w/ multi fit valve pockets (any compression available)
-NPR stainless chrome top ring, napier 2nd, 3mm HT oil rings (for high heat applications)
-Clevite H series main & rod bearings
-Dura Bond one piece cam bearings
-ARP main studs
Reg. $7399
Sale $6649
LSX BOWTIE 427”,440”,454”
-GM LSX block w/ priority main oiling, billet main caps & 6 bolts per cylinder
-Callies Compstar 4340 4.0” stroke crankshaft (4.125” stroke for 454”)
-Wiseco forged nitrous pistons w/ multi fit valve pockets (4.125” for 427, 4.185” for 440” & 454”)
-Total Seal stainless chrome top ring, napier 2nd, 3mm HT oil rings (for high heat applications)
-ARP main studs
Reg. $7399
Sale $6699
LS3 416 CID.
-GM LS3 aluminum block
-Wiseco forged 4.070” nitrous or FI pistons w/ multi fit valve pockets (+5cc,-3cc,-8,-15,-20cc,-32cc available)
-ARP main studs
Reg. $5649
Sale $5099
LS2 402 CID.
-GM LS2 aluminum block
-ARP main studs
Reg. $5349
Sale. $4699
IRON 408 CID.
-ARP main studs
Reg. $5099
Sale $4199
**Shortblock blueprinting process summary.
-Block is inspected for flaws and when cleared for use is fully deburred inside & out, line honed to low of spec w/ ARP main studs (establishing crankshaft center line as well as insures proper bearing crush), deck surfaces cut using BHJ deck true fixture insuring perpendicular deck surfaces & optimum quench distance, cylinders bored (when required) using 3 axis CNC mill, cylinders honed w/ torque plate to required clearance for specific application, block is machined as required for rod bolt clearance, block is final inspected and extensively cleaned for assembly. Each crankshafts stroke is individually indexed on a Berco crank grinding machine and all journals are measured for alignment, roundness and taper. Any corrections necessary are made to insure a perfect crank from post to rear seal. Crankshaft is balanced to ¼ oz. in. tolerance. During final assembly ring end gaps are adjusted for application and all bearing clearances are adjusted for application. All oil galley plugs & dowel pins are installed.
<<MAKE IT A LONGBLOCK>>
-Trick Flow 225cc or 235cc intake runner CNC ported cylinder heads. Parts: Ferrea one piece stainless intake & exhaust valves, Dual valve springs good to .650” lift, titanium retainers, machined locks, machined locators, viton seals w/ steel jacket.
All Trick Flow heads installed on LME shortblocks are completely disassembled and inspected, valve job is lapped in to insure proper sealing, valve job is hand blended into ports and flow tested to insure advertised air flow is met or exceeded, valve guide to valve stem clearance measures & adjusted for application, combustion chamber volumes measured and adjusted for desired compression ratio, spring pressures measured & adjusted for camshaft.
-Cam Motion custom camshaft
-JP Performance double roller timing chain w/ Torrington bearing
-GM cam retainer plate w/ bolts
-GM LS7 hyd. Roller lifters
-GM lifter trays w/ bolts
-ARP pro series 12 pt head stud kit
-Cometic MLS head gaskets
-Manley one piece chromoly push rods
-Yella Terra Ultra Lite roller rockers (1.7 or 1.8 ratio based on application)
-Melling 10295 coated & ported HP oil pump
-LS2 to LS1 conversion kit: LS2 front cover, LS2 valley cover, cam sensor/knock extension harness
All longblocks will have camshaft degreed & adjusted for application, piston to valve clearance measured & adjusted, rocker arm geometry set and push rod length measured & adjusted for proper lifter pre load. LS2 front cover is clearanced for double chain & oil pump and installed
Longblock upgrade:
Reg. $5199
Sale $4749
Complete longblock pricing includes assembly:
LS7 430”, 440” = $11,348
LSX 427”, 440”, 454” = $11448
LS3 416” = $9848
LS2 402” = $9447
IRON 408” = $8947
LME offers many other options on short and longblock combinations. Hand ported LS7 & L92 top end combinations also available.
We will be happy to talk with you to determine the best combination for your application.
Please feel free to ask any questions via phone, PM or email.
Thank you,
Bryan Neelen
LME
713-849-4505
sales@latemodelengines.com
01SLPSS
01-09-2009, 12:27 AM
wish i had the money now....gonna pick a shortblock up in the very near future...hope you guys will have another sale like this...
sr71bbjr
01-12-2009, 01:33 AM
No sale on the 35k race motors? Haha damn I need to bring you a block already.those are some great deals there btw! I've used lme for a few builds and never been disapointed or had one problem! Hell that includes my dads 3 yr old 408ci 534rwhp 6 speed street car we beat the piss out of! I can't count the amount of times that things takin a 300 shot with no issues.
Bryan Pomeroy
Bryan@LME
01-19-2009, 09:46 AM
TTT for today!
Bryan@LME
01-27-2009, 04:03 PM
TTT for the last week of this sale!!
Thank you for the orders & good words.
Late Model Engines
713-849-4505
