Help!!!
Old 01-08-2009, 04:04 PM
97T/A's Avatar
Default Help!!!
does anyone have a site or a thread they know of that has a step by step or close to step by step for h/c swap?
Old 01-08-2009, 04:06 PM
SprayedLT1's Avatar
Hayne's manuals are usually pretty handy for that.
Old 01-08-2009, 04:08 PM
97T/A's Avatar
well i do have a chilton manual which is pretty much the same thing but im still looking for some additional sources
Old 01-08-2009, 04:09 PM
PNYKLR-TA's Avatar
yea i'd say the chilton should have all the info you'd need, otherwise do some google searches and see what you get.
Old 01-08-2009, 05:25 PM
ss.slp.ls1's Avatar
Here you go:
http://www.afrashteh.com/guide/install.htm
Old 01-08-2009, 06:59 PM
97T/A's Avatar
Originally Posted by ss.slp.ls1
thanks looks like a pretty solid writeup
Old 01-08-2009, 07:13 PM
ss.slp.ls1's Avatar
These are also very good:
http://shbox.com/ci/cam_removal.html
http://shbox.com/ci/cam_install.html
Old 01-08-2009, 08:27 PM
97T/A's Avatar
anyone have any threads?
Old 01-08-2009, 08:32 PM
ss.slp.ls1's Avatar
Anyther invaluable resource is the How to Rebuild Chevy-Small Block LT1/LT4 Engines.
http://www.amazon.com/Rebuild-Small-.../dp/1557883939
It has complete step by step instructions, with pictures and torque specs! Mine is absolutely covered in grease from using it.
Old 01-08-2009, 08:44 PM
97T/A's Avatar
did you use that for your cam or h/c swap? thanks for helpin out by the way. im startin to buy the parts now and have a lot of internet knowledge about f bodys but no hands on experience thats why im doin it with my friend whos got the hands on experience except its with his 5.0
Old 01-08-2009, 08:49 PM
andrew ws6's Avatar
Try this one
http://www.ls1lt1.com/forum/showthread.php?t=16179
Old 01-08-2009, 09:01 PM
97T/A's Avatar
Originally Posted by andrew ws6
great info thanks! another question for anyone reading is how many of you guys have done it with the motor in and who has done it with the motor out?? which one do you suggest??
Old 01-09-2009, 07:48 AM
ss.slp.ls1's Avatar
I did use that book when I was building my new engine, its a great resource.
When I cammed my LT1, I was also replacing the motor, so I did the whole thing with the engine on a stand, soo much easier. If you were only doing a cam, I'd say leave it in, since you are doing heads and cam, I would drop it out. But remember this is comming from someone who has dropped it out several times before, it's not too difficult.
Old 01-09-2009, 11:18 AM
JB_97ws6TA's Avatar
+2, I just put my motor back in last night from doing a cam swap and having some head work done. It is really easy to drop the k-member and believe it or not putting it back in went really smooth. You are probably going to have to change torque converters depending on the cam so it is faster and easier just to drop the whole thing. The motor is back in K-member is torqued, I just have to plug everything in and service, bleed brakes, etc. and I have 26 hours invested so far, first timer, can be done much faster I am sure but I am happy with it.
Old 01-09-2009, 11:34 AM
djjab57's Avatar
about a year ago i bout a dvd off ebay with step by step and lot of pics ill see if i cant find it i know i downloaded it on my computer
Old 01-09-2009, 11:47 AM
djjab57's Avatar
here is one
http://cgi.ebay.com/ebaymotors/_Manu...1%7C240%3A1318
Quick Reply: Help!!!
