mebuildit
01-11-2009, 12:31 PM
Ok guys / gals (there are some on here). I am getting ready to pull the trigger on an engine. But I have several questions about the build. Some things I do know that I want to use and others I just don't know what a good combo will work for my application. Also, I would like to know who you would reccomend to build this engine.
OK here goes:
This motor will be going into a 4 seater off road pre runner buggy, so I will require some low to mid range torque, will weigh about 3000lbs. I don't mind spending the extra money for better parts as long as they are of good quality. I don't want to build a time bomb, with cheap parts. It also will be normally aspirated so here is my list:
LSX 454 iron block
Crank- Callies or Lunati?
58T
ARP studs and fasteners for whole engine 12pt.
Heads- AFR cnc'd
Valves-Ti / Stainless
Jesel or T&D rockers
Rods-Callies?
Bearings- coated-which brand
Pistons- Diamond / JE / Weisco?
Cam- Brand? size?
Dual timing chain?
intake manifold- Marcella
Throttle body? size / brand
Pushrods?
Lifters- Jesel / Isky EZ roll?
I would also like to have the wrist pins Casidiam coated, valve springs coated, pistons coated and have the block bushed for lifters
Also needs to be dry sumped.
Hopefully, I covered most of what I will need. Now it's up to you guys on what combo works best.
Thanks in advance for your time and efforts for helping me build a nice enigne.
OK here goes:
LSX 454 iron block
58T
Heads- AFR cnc'd
Rods-Callies?
Cam- Brand? size?
Dual timing chain?
Pushrods?
