439 rwhp N/A stock heads
I have a 2000 z 6 spd it put down 439 on a mustang dyno here are my mods
Tsp 233/239 113 lsa and supporting mods
Slp long tubes and a 3" ORX
Ls6 w/ported tb
Underdrive
Hp tuners
The power was in 4wd mode which I heard was similar to a dyno jet in regular it put down 425 hp and 408 torque.
Tell me what you think?
Ls6 w/ported tb
Underdrive
Hp tuners
It was dialed in to read like another dyno which means there is no way to tell how accurate it really is. I'd dyno on an actual dynojet to get your comparable numbers. They are definitely way high numbers for those mods but that can be attested to the dial your own HP number.
Same tuner it's just the big intake lobe seemed like it helped out the idle and I have the idle set a little lower to but I like it. And there is a long story behind why I got rid of the cam but besides this being a different car I wanted a good set of heads with stock pistons I would have broke the motor. Cuz the ms4 slightly hits anyways so...
