U7198 Shift pressure and shift firmness question
Old 01-12-2009, 04:55 PM
zrultima's Avatar
Default U7198 Shift pressure and shift firmness question
I have a 01 Z28 with a u7198 predator and my question is about shift pressure and shift firmness> I just had my tranny rebuilt I Lost 2nd gear lol. Well my question is will changing shift pressure *making it higher* and shift firmness mess up my tranny someone help . Also does this do the same thing as a shift kit???!?!?
Old 01-12-2009, 05:14 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Adding line pressure will generally keep the tranny alive longer since it eliminates slippage between gears, which keeps heat down in the tranny, and heat is a transmissions #1 enemy.
It is similar to adding a shift kit, yes.
Thanks
Mike
Old 01-12-2009, 05:20 PM
zrultima's Avatar
how about if i put the shift firmness all the way up???? what happens there
Old 01-12-2009, 05:28 PM
zrultima's Avatar
also does torque management hurt the tranny???
Old 01-13-2009, 12:14 AM
zrultima's Avatar
how about putting part throotle frimnes to 25 psi and wot pressure the same??will this hurt the transmission?
Old 01-13-2009, 08:56 AM
LS1Tech Sponsor
We do not allow you to go far enough to hurt anything, so feel free to add pressure until it is where you like it.
TM is what protests the tranny from making too much torque, turning it off will allow you to make as much power as possible without the PCM stepping it, but it may shorten the life of stock drivetrain parts in a high HP application.
Old 01-13-2009, 06:40 PM
zrultima's Avatar
I put part throttle shift and wot pressure to 15 psi couldnt really tell the difference
Old 01-14-2009, 08:20 PM
zrultima's Avatar
if you can help me with my tune i put it on diablosport mikel
Quick Reply: U7198 Shift pressure and shift firmness question
