yank conv. ?'s
yank conv. ?'s
hey guys,I bought a used yank ss3600.brand new in box for a great deal.$470,but I have a few questions.the part # on the box says ss36000ls2.on the converter its written 3600 in permanent marker.
1.on the converter it says 3600ls1/04/07.what are the later numbers 04/07,manufacture date?
2.converter seems heavy.lighter or heavier than stock?
pics are attached.what else needs to be done to run effectively.thanks hopefully its the right one that way I can make the S.I list
You should be fine. Go put that baby in. While your in there you may want to put in a new input shaft seal. Only costed me $1.62 at Napa with my discount. And don't worry the bolts that came with the converter and perfect sized, if your running the stock flexplate. (They look a little small), good luck - Zack
