Is there any benifit t odeleteing the AIR off of a 2002 ls1?
Old 01-15-2009, 07:26 AM
bigfatls6's Avatar
Default Is there any benifit t odeleteing the AIR off of a 2002 ls1?
I am installing a TSP 85mm lid and ZO6 85mm mass air and the lid doesn't have the provision for the air hose on my 2002 camaro. I am trying to decide between just eliminating the air. or just use a filter on the air hose that goes on to the air lid.
Old 01-15-2009, 08:44 AM
rooster99ss's Avatar
I don't think there's a performance difference at all. a little weight loss (probably about 5-8lbs) and it cleans up the engine bay a bit. i deleted mine
Old 01-15-2009, 09:18 AM
slayer_taunu's Avatar
ditto what rooster said.
if you have stock manifolds you need blockoff plates. and i'm pretty sure there is a code to delete or else you'll throw an SES. been too long since i removed mine... can someone confirm that?
Old 01-15-2009, 10:22 AM
jermstyle's Avatar
Get rid of it!
Old 01-15-2009, 11:20 AM
it'll throw a check engine light, but it's easy for someone with a tuner to tune out. when i had the tune put on my car, they just tuned it out while they were in there
Old 01-15-2009, 02:45 PM
KCS
Moderator
KCS's Avatar
Easier to change plugs.
Old 01-15-2009, 03:27 PM
Greed4Speed's Avatar
Easier to get a ticket for missing smog equipment.
Is that DPS dillhole in Houston still pulling people over and checking?
Old 01-16-2009, 01:47 AM
bigfatls6's Avatar
The car is going to ARD tomarrow I will see if they can go ahead and delete it while its there and tune it out.
Old 01-16-2009, 08:25 AM
01-02 cars came from the factory without EGR... is a DPS officer going to know the year to year changes of vehicle emission systems?
Old 01-16-2009, 11:05 AM
MESS's Avatar
you never know, they nothing else to do
