opinons need!?!?
opinons need!?!?
just bought a camaro its a 98 with 100k miles, the guy i bought it from didnt know anything that was on it so i got it for $6,000 so far the mods i found are.
pacesetter ceramic headers with copper gaskets, LS6 intake, MTI lid, mobil one synthetic oil, granatelli plug wires, low temp thermostat, B&m short throw.... anything else i can look for? it has an aluminum driveshaft so that means most of the time those have 3.73 gears? i believe it needs subframe connectors because the exhaust hits the floorboard becasue of the 3 in y-pipe on it? and makes a weird ticking noise on startup but quits immediately after. ive come to two conclusions.... the ticking of injectors because of the intake? or tooth missing on flywheel?.... overall car is a 9 on a 10 scale. very very clean
SFC's will do nothing for the Y hitting the floor pan. Youneed to readjust the way your Y sets.
When did oil become a mod?
in addition to that i just got outrun by my buddies 08 G8 GT. so i researched it and it said they run 13.6 in the quarter mile and i expected mine to be in the low 13's based on my mods... but we did a 30 punch and i couldnt seem to catch up guess my driving could be better but it was a letdown
Most headers will be blocked off anyways unless you get an off road set which they wont even be there, its normal. As far as finding what else is on the car, post pics, also look for a number on the head, 3 digits and tell us what that casting number is.
241
243
853
806 (98 heads, perimeter bolt)
should be something like the above, the others should be center bolt valve covers.
241
243
853
